Vanquish Tier 3 cooling limits?Post Date: 2013-11-09 |
ChrisKirkman
Newbie Joined: 13 Jul 2013 Online Status: Offline Posts: 81 |
Topic: Vanquish Tier 3 cooling limits? Posted: 09 Nov 2013 at 7:12pm |
I would just like to know just what is the heat/cooling limit for the Vanquish tier 3, and How long can you play on it without having it over heat and cause damage to any interior components. Thank You!
Nomad1970
Senior Member Joined: 23 Feb 2013 Online Status: Offline Posts: 716 |
Quote Reply Posted: 09 Nov 2013 at 7:28pm |
Unless something bad happens, forever. Everything should either throttle back or shutdown if there is a heat problem.
My Precious 2
I7-9700 oc 4.7GHz 32GB DDR4 3000MHz Corsair Vengeance RGB Pro SSD M.2 (512GB Samsung 970 PRO) SSD M.2 1TB Samsung 970 EVO 240GB Samsung 860 Pro SSD 1TB W.D. HD EVGA GTX 1080Ti |
