Vanquish II Level 3Post Date: 2014-08-28 |
Farmall200
Newbie Joined: 28 Aug 2014 Online Status: Offline Posts: 6 |
Topic: Vanquish II Level 3 Posted: 28 Aug 2014 at 7:52pm |
Hello,
Quick question, I plan on purchasing a Vanquish II level 3 in the next few days. In my house, I do not have the option of hard wiring the computer, so I am wondering if I can fit this in the Vanquish II case (I know its a Micro ATX board), or if I need to get a USB based wifi adapter. FYI: Linksys EA3500 N750 Dual Band Smart Wi-Fi Router (Wifi Router, if it isn't obvious ) Thanks all! Update! Since I cant put links in my posts( ), just google this: TP-LINK TL-WDN4800 Dual Band Wireless N900 PCI Express Adapter,2.4GHz 450Mbps/5Ghz 450Mbps Thanks all! |
Signature? Who uses those anymore?
Quote Reply Posted: 28 Aug 2014 at 9:46pm |
Just get the USB Wifi Adapter. I just picked up a NetGear N300 WiFi USB adapter for my Vanquish II level 4 and it works like a champ.
This is up to 300Mbps which far and away exceeds my ISPs speed plan. After installing current drivers, it took all of 2 maybe 3 minutes to get up and running. |
Farmall200
Quote Reply Posted: 31 Aug 2014 at 7:20pm |
Okay, I wasnt sure, right now there both the same price, and the pcie card has better specs. I guess I'm wondering more if I can fit it in the first place, I'm not sure on the space in the case with such a small mobo and big gpu.
