Vanquish II Level 2 questions.Post Date: 2014-04-01 |
slashx24
Newbie Joined: 29 Mar 2014 Online Status: Offline Posts: 5 |
Topic: Vanquish II Level 2 questions. Posted: 01 Apr 2014 at 1:16pm |
Okay so I am saving up for the Vanquish II Level 2 , and I'm wondering what games it can possibly play. I can play them on low-High so doesn't really matter. So can someone tell me what games I can expect it to play. I havn't seen any reviews on the level 2 so I would need some advice :) I would like to know if I can play modern games, and games that may come out soon.
Quote Reply Posted: 01 Apr 2014 at 1:42pm |
The Vanquish level 2 with gtx 750ti can play pretty much anything out there.
Here's a link showing some examples. http://www.anandtech.com/bench/product/1130 Hope this helps. |
Quote Reply Posted: 01 Apr 2014 at 3:47pm |
http://www.digitalstormonline.com/forums/vanquish-ii-benchmark-data-tidf22242/
Here's a link to a Vanq 2 benchmark that Alex posted. I'd really like to point out the jump from level 2 to level 3. Notice the difference of 20+ fps when going from an i3 to an i5. I can't recommended at bare minimum getting the i5 over the i3. If that means going months more just to save. It's definitely worth it. Can't stress that enough. But at least this gives you an idea, on top of Bprat22's link included. |
Quote Reply Posted: 01 Apr 2014 at 4:01pm |
The graphics card from the Level 2 to Level 3 is what is really making the performance boost for games.
Quote Reply Posted: 01 Apr 2014 at 4:06pm |
Yep, a good 40% increase in gaming from Vanquish 2 to 3.
slashx24
Quote Reply Posted: 03 Apr 2014 at 2:52pm |
Does anyone have a review on them?
Quote Reply Posted: 03 Apr 2014 at 3:01pm |
The Vanquish 2 are too new to have reviews. Your best bet to figure gaming performance is to look at the video card in each. It's not exact because of variables but gets you close. The link I posted earlier in this thread allows you to plug in the various cards to compare. Also the link Meller posted will help.
AshesDen
Groupie Joined: 30 Mar 2014 Online Status: Offline Posts: 104 |
Quote Reply Posted: 03 Apr 2014 at 5:24pm |
The Vanquish II is a very good computer. And it is made for gaming (thus in the gaming category.) With the GTX 750 you should be able to run things fairly well! Although there are better cards, you can run things no problem. If you have the money for the 2, I suggest upgrading too the third! It makes a huge difference, and if your serious about gaming the Level 4! All upgrades are 100% worth it. i5 Processors are the Best for gaming, so obviously get the best you can get. Look around for Reviews on Each item :) But if you REALLY wan't to run games, then go for level 3 (level 4 if you have the money).
A little off topic, but change Windows 8 too 7, so much better, and way easier to navigate. I personally think Windows 8 was a huge disappointment to the Windows Series :P With you luck with your Computer! And you won't be disappointed with Digital Storm! |
Can't Wait to get my New Computer!
Specs: Intel i7-4770k NVIDIA GTX 770 2GB SuperClocked Digital Storm 120mm Radiator |
