System Clock
Post Date: 2014-03-11
wright View Drop Down
  Quote wright Quote  Post ReplyReply bullet Topic: System Clock
    Posted: 11 Mar 2014 at 11:50am
Hello, Yesterday I cloned my Samsung 256GB 840 Pro to  a new Samsung 1TB 840 EVO. The clone was successful using XXClone. OS, games, flight sim, files, all of it cloned perfect. The alignment of the disk was good also, however, the only problem I have since the clone is that the system clock does not keep the right time since the clone? I went into bios to check to check the time there and it was wrong also? I bought my Hailstorm ll last July and never had a problem with the clock.  I did not check the battery because never had a reason to maybe til now? This was my first clone and I don't know if that had any thing to do with it. Has anyone else heard of this? My MB is an Asus Sabertooth Z 87.  I did not flash the bios, never did that before. Don't know if that will help? Anyway, if anybody might know a fix for this I sure would appreciate it. I really need the clock and date to work...... Thanks
Regards
Lamar Wright
Hailstorm ll
i7 4770K OC
Z 87 Chip set
16 GB DDR3 1866 MHz
Stage 2 cool 240mm Radiator
GPU 1x GTX 780 3GB
Samsung 256GB SSD
1TB WD Caviar
Corsair 120mm performance fans
  Quote wright Quote  Post ReplyReply bullet Posted: 11 Mar 2014 at 11:54am
Hailstorm ll
i7 4770K OC
Z 87 Chip set
16 GB DDR3 1866 MHz
GPU 1x GTX 780 3GB
Samsung 256GB SSD
1TB WD Caviar
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 11 Mar 2014 at 12:58pm
Sounds like the battery but I'd try this first...
Turn off and unplug the rig.   Hold power button in for several seconds and then plug in , etc and try it.
Clear CMOS. Check your mobo manual for procedure. Probably a jumper on mobo. If you clear CMOS, you'll need to reload overclock profile in Bios.
  Quote wright Quote  Post ReplyReply bullet Posted: 11 Mar 2014 at 4:52pm
Thanks bprat22 for that information, I will do that exactly. I'll report back when it is fixed,   Thanks again
Hailstorm ll
i7 4770K OC
Z 87 Chip set
16 GB DDR3 1866 MHz
GPU 1x GTX 780 3GB
Samsung 256GB SSD
1TB WD Caviar
  Quote wright Quote  Post ReplyReply bullet Posted: 12 Mar 2014 at 3:53pm
Hi Bprat22, tried solutions and clock still after about 30 min after reset clock the time changes? I set the bios clock and then the system clock and clock is fine for 30 min or so. This is real weird, never had this to happen. Any thing else I can try?
Hailstorm ll
i7 4770K OC
Z 87 Chip set
16 GB DDR3 1866 MHz
GPU 1x GTX 780 3GB
Samsung 256GB SSD
1TB WD Caviar
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Mar 2014 at 4:16pm
I would disconnect your rig from the internet, wifi or Ethernet, to make sure it's not setting your clock to the wrong time. Play a game or whatever for an hour or so and check the clock.
If still a problem, probably the battery.
  Quote wright Quote  Post ReplyReply bullet Posted: 12 Mar 2014 at 5:36pm
Thanks Bprat22 I'll try that, if still the same I'll change the battery. Thanks and I'll let you know,
Hailstorm ll
i7 4770K OC
Z 87 Chip set
16 GB DDR3 1866 MHz
GPU 1x GTX 780 3GB
Samsung 256GB SSD
1TB WD Caviar
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Mar 2014 at 6:20am
Got one more thing. Hahaha
  Right click the task bar clock, select adjust time, go to Internet Time tab , change settings and Update Now to sync to internet.
Running the Windows Repair with OS disc might find a corrupted file.
You and another are having system clock issues on the forum.  Must be a bug going around. Big%20Smile
  Quote wright Quote  Post ReplyReply bullet Posted: 13 Mar 2014 at 8:25am
Thanks Bprat22, I will try that also..........Let you know
Hailstorm ll
i7 4770K OC
Z 87 Chip set
16 GB DDR3 1866 MHz
GPU 1x GTX 780 3GB
Samsung 256GB SSD
1TB WD Caviar
