[SOLVED] Help deleting files
Post Date: 2012-07-07
bdkraem View Drop Down
  Quote bdkraem Quote  Post ReplyReply bullet Topic: [SOLVED] Help deleting files
    Posted: 07 Jul 2012 at 1:31pm
Hey everybody.  I purchased an ODE Level 2 system awhile back and I recently installed Windows 8.  Today I "downgraded" back to Windows 7.  That Win 7 reinstall went smoothly enough, but now over half of my SSD boot drive is being used by a windows.old file.  I'm trying to delete the Windows.old folder but the old system files inside are protected.  I made sure to take off read-only from all the files and folders and I even tried using the 'del' command in the command prompt.  Any advice?
 Thanks for your help!
Edited by bdkraem - 07 Jul 2012 at 1:49pm
  Quote bdkraem Quote  Post ReplyReply bullet Posted: 07 Jul 2012 at 1:47pm
Never mind! I figured it out. If you use the Disk Cleanup utility it gives you the option do deleting previous installations of windows. This cleared it up.
  Quote Alex Quote  Post ReplyReply bullet Posted: 07 Jul 2012 at 11:02pm
Cool
