Sharing my BuildPost Date: 2015-02-24 |
Gnicky
Newbie Joined: 05 May 2011 Online Status: Offline Posts: 74 |
Topic: Sharing my Build Posted: 24 Feb 2015 at 8:28am |
I have finalized the configuration for my second DS system and thought I would share here. I'll plan to post pics when it arrives. I'm not sure who is more excited between me and my son, who will be inheriting my current system. Here is the configuration (I will be installing my 512 SSD also):
System Configuration: Chassis Model: Special Deal Hot Seller - Digital Storm Coridium Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 5820K 3.3GHz (Six-Core) (Unlocked CPU) Motherboard: ASUS X99-DELUXE (Intel X99 Chipset) System Memory: 16GB DDR4 2800MHz Corsair Dominator Platinum DHX (Extreme-Performance) Power Supply: 850W EVGA SuperNOVA Expansion Bay: - No Thanks Optical Drive: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST) Storage Set 1: 1x SSD (256GB Samsung 850 PRO) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 980 4GB (ASUS Strix Edition) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H110 280mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: Remote Controlled LED Lighting System (Multiple color options and lighting effects) Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Graphics Boost: - No Thanks, Please do not overclock my video card(s) Memory Boost: - No Thanks, Please do not overclock my memory OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) |
Quote Reply Posted: 24 Feb 2015 at 8:34am |
Looks like a solid setup
Quote Reply Posted: 24 Feb 2015 at 8:39am |
I'll second what Nav said.
Gnicky
Quote Reply Posted: 24 Feb 2015 at 8:49am |
Thanks for the feedback. It was difficult for me to pick a case between this (450d), the 760T, and the Air540. It was the aesthetics, size, and air filters that won me over in the end.
Moderator Group Just a dude trying to keep the spam away Joined: 23 Jan 2014 Online Status: Online Posts: 9462 |
Quote Reply Posted: 24 Feb 2015 at 9:24am |
Quote Reply Posted: 24 Feb 2015 at 9:48am |
Those cases are tough choices. Whenever I pretend-build , I always go with the Air 540 but then wander to the 760T and Velox. I have recommended the Coridium a number of times because it is a nice airflow case.
I do miss cases with the side panel fan cutouts like your HafX and my 600T. It's a good option if heat becomes an issue in the future. They all work. Son of a gun....Just noticed that the HafX is back as an option. Edited by bprat22 - 24 Feb 2015 at 9:51am |
Gnicky
Quote Reply Posted: 24 Feb 2015 at 1:24pm |
Yes, I also noticed the HAF X is back - such a great case.
I hope I don't regret not getting the AIR 540 - and could have gotten the extended motherboard also (not that I "need" it). But I really like the top/bottom/front filters on the 450d. Even though I think my PC is in a reasonably dust-free environment, it seems I still blow a lot of dust out. And I plan on taking the cage out of the case entirely. so the airflow should be very clean. Edited by Gnicky - 24 Feb 2015 at 1:25pm |
Gnicky
Quote Reply Posted: 26 Feb 2015 at 5:12pm |
Stage 3 - yeah!
Decided to go with the Air 540 and Rampage V MB - can't wait... Edited by Gnicky - 26 Feb 2015 at 5:15pm |
Quote Reply Posted: 26 Feb 2015 at 5:26pm |
Air 540. We've been having a good discussion with Dax on another thread. Under General Discussion.
Dax Doomslayer
DS Veteran Keeper of the commas Joined: 29 Apr 2012 Online Status: Offline Posts: 4743 |
Quote Reply Posted: 27 Feb 2015 at 9:03am |
Yes! Pretty cool case nice choice Gnicky!
Gnicky
Quote Reply Posted: 27 Feb 2015 at 1:47pm |
Thanks for the feedback, I thought I might me a little less excited this time, but no luck - checking every 30 minutes for a build status change.
Kaelara
Quote Reply Posted: 27 Feb 2015 at 8:56pm |
Case choices are always hard for me to make... Room, looks airflow all factors to take in.. I decided to go with the Velox and for a mainly air cooled system with the fan upgrade it is a good choice.
However if you are in a very dusty or dirty environment it may not be ideal :P I will know more if it passes the true test of a good case for me, whether it can handle Texas Summer heat and still keep things cool. If it has problems I will be sending the entire system back to DS to have a full Water Cool system installed an expense I hope to not have to do. Nice build, I also went with the Rampage MOBO and am totally satisfied. Edited by Kaelara - 27 Feb 2015 at 8:57pm |
Kaelara
Dax Doomslayer
Quote Reply Posted: 28 Feb 2015 at 8:05am |
Both are great cases. You folks should be pretty happy with your choices! You'll have to report back and let us know.
