Refrigeration Cooling System For PC
Post Date: 2008-09-23
Nomak View Drop Down
  Quote Nomak Quote  Post ReplyReply bullet Topic: Refrigeration Cooling System For PC
    Posted: 23 Sep 2008 at 4:52pm
- Utilize micro compressor and refrigerant to cool PC, to maximize over-clocking limitation and performance
- 20ºC cooler than liquid cooling System
- Equipped with intelligent IC controller to prevent condensation
- Thermal resistance can be <0.02 ºC/W under 100% loading
- High performance micro compressor uses standard 12V power
- Small, low noise, high performance technology
Compatible mobos:
MSI:
P45 Diamond / P45 Platinum / P45D3 Platinum / P7N Diamond (Only for one VGA card plug in 4th slot) / P7N2 Diamond (Only for one VGA card plug in 4th slot) / X48C Platinum (Only for one VGA card plug in 4th slot)
Gig:
EP45-DQ6 / EP45T Extreme (DDR3) / EP45 Extreme (DDR2) / X48T-DQ6 (DDR3) / X48-DQ6 (DDR2)
Asus:
Blitz Formula / P5Q / P5QC / P5Q Pro / P5Q Deluxe / P5E Deluxe
Something for DSO to look into.  Smile
Edited by Nomak - 23 Sep 2008 at 4:52pm
Axel Daemon View Drop Down
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 23 Sep 2008 at 5:00pm
Mwahaahah.  I knew it!  It was gonna happen eventually I didn't think it was gonna happen so soon though.  Happy days!
"People believe in people who believe in others."
  Quote Nomak Quote  Post ReplyReply bullet Posted: 23 Sep 2008 at 5:04pm
Approve
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 Sep 2008 at 5:17pm
Let them be out for a bit then, if its new its got some kinks
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 23 Sep 2008 at 5:24pm
@Nomak:  What?  The reason I reacted like that was because I was joking about refrigerator computer cases.  And now see what happened! Lol.
MarkNY View Drop Down
  Quote MarkNY Quote  Post ReplyReply bullet Posted: 23 Sep 2008 at 5:24pm
wouldn't those metal pipes leave condensation which would drip onto the motherboard?
nm- i guess they have foam around them- but who nows how effective.
Edited by MarkNY - 23 Sep 2008 at 5:26pm
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 23 Sep 2008 at 5:25pm
That's why that site pointed out there's some specific part designed to avoid the condensation.
  Quote Nomak Quote  Post ReplyReply bullet Posted: 23 Sep 2008 at 5:34pm
*waits for DSO reps*
Ouch
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 23 Sep 2008 at 7:03pm
What's it to you?
You're not expecting them to add this to their line of cases so suddenly now do you?
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 23 Sep 2008 at 11:52pm
Phase change cooling isn't new, but this is the first time i have seen soneone actually try to put the compressor inside the case with the system. One thing I want to point out, aside from the obvious drawbacks to putting a source of heat inside the case (the compressor) is that with phase change cooling, you have to be careful of condensation on the cooling lines. Dripping water is very bad for electronics. Smile
Chris W. View Drop Down
Digital Storm Tech Support
  Quote Chris W. Quote  Post ReplyReply bullet Posted: 24 Sep 2008 at 12:58am
We have a test phase change system we put together for NVISION as far as I know its still under research
<img src="http://www2.razerzone.com/tag-generator/label_images/1222492484_2122770270.jpg" border="0" />
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 24 Sep 2008 at 2:57am
The complexity of phase change cooling is no different than creating a refrigerator. The problems only come in with trying to make it so small. The condensation control has to be a near complete "sealed" insulation layering of the cold lines feeding from the condenser to the cooling block. Any condensation on the lower lines can drip down harmlessly if everything is run along the bottom of the case. An A/C uses a tray to collect and drain condensation in this manner. IMO, phase change is the current limit of how far "practical" cooling can go for pcs.
Now, I can just imagine calling my A/C repairman in to fix my pc... LOL! Would he have some stories to tell back at the office...Approve
