Questions on ports and wires
Post Date: 2014-10-05
saqib126 View Drop Down
  Quote saqib126 Quote  Post ReplyReply bullet Topic: Questions on ports and wires
    Posted: 05 Oct 2014 at 7:53am
The motherboard I want to use for my new computer does not mention have a six pin slot, and my graphics card requires two, do I need a different motherboard? It is a ASUS MAXIMUS VII HERO. Here is my motherboard`s specs
CPU
Intel® Socket 1150 for the 5th/New 4th/4th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
Supports Intel® 22 nm CPU
Supports Intel® Turbo Boost Technology 2.0
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
* Refer to www.asus.com for CPU support list
Chipset
Intel® Z97
Memory
4 x DIMM, Max. 32GB, DDR3 3200(O.C.)/3100(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666(O.C.)/2600(O.C.)/2500(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory *
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists).
Graphic
Integrated Graphics Processor- Intel® HD Graphics support
Multi-VGA output support : HDMI/DVI-D/RGB ports
- Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz / 2560 x 1600 @ 60 Hz
- Supports DVI-D with max. resolution 1920 x 2000 @ 60 Hz
- Supports RGB with max. resolution 1920 x 2000 @ 60 Hz
Maximum shared memory of 512 MB
Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Supports up to 3 displays simultaneously
Multi-GPU Support
Supports NVIDIA® Quad-GPU SLI™ Technology
Supports AMD Quad-GPU CrossFireX™ Technology
Expansion Slots
2 x PCIe 3.0/2.0 x16 (x16 or dual x8, red)
1 x PCIe 2.0 x16 (x4 mode, black) *1
3 x PCIe 2.0 x1 *2
Storage
Intel® Z97 chipset :
6 x SATA 6Gb/s port(s), red
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *3
1 x M.2 Socket 3, blackwith M Key, type 2260/2280 storage devices support (PCIE mode)
ASMedia® PCIe SATA controller : *4
2 x SATA 6Gb/s port(s), red
LAN
Intel® I218V, 1 x Gigabit LAN Controller(s), featuring GAMEFIRST III
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Anti-surge LANGuard
Audio
ROG SupremeFX 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- ELNA premium audio capacitors
- Blu-ray audio layer Content Protection
- DTS Connect
- Optical S/PDIF out port(s) at back panel
- Sonic SoundStage
- Sonic SenseAmp
- Sonic Studio
- Sonic Radar II
USB Ports
6 x USB 3.0/2.0 port(s) (4 at back panel, blue, 2 at mid-board)
Intel® Z97 chipset : *5
7 x USB 2.0/1.1 port(s) (2 at back panel, black, 5 at mid-board)
ROG Exclusive Features
Extreme Engine Digi+ III :
- 8 + 2 phase power design
- NexFET™ Power Block MOSFET
- 60A Ferrite Chokes
- 10K Black Metallic Capacitors
KeyBot
- CPU Level Up
- XMP
- Direct Key
UEFI BIOS features :
- GPU.DIMM Post
- Tweakers' Paradise
- ROG SSD Secure Erase
- Graphic Card Information Preview
ROG RAMDisk
GameFirst III
Extreme Tweaker
Special Features
ASUS Dual Intelligent Processors 5-Way Optimization by Dual Intelligent Processors 5 :
Gamer's Guardian:
- ESD Guards on LAN, Audio, KBMS and USB3.0/2.0 ports
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
ASUS Exclusive Features :
- MemOK!
- AI Suite 3
- Ai Charger
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS USB BIOS Flashback
- Push Notice
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Media Streamer
Operating System Support
Windows® 8.1
Windows® 8
Windows® 7
Back I/O Ports
1 x PS/2 keyboard/mouse combo port(s)
1 x DVI
1 x D-Sub
1 x HDMI
1 x LAN (RJ45) port(s)
4 x USB 3.0 (blue)
2 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x USB BIOS Flashback Button(s)
Internal I/O Ports
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
3 x USB 2.0 connector(s) support(s) additional 5 USB 2.0 port(s)
1 x M.2 Socket 3 for M Key, type 2260/2280 devices
1 x TPM header
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s) (1 x 4 -pin)
1 x CPU OPT Fan connector(s) (1 x 4 -pin)
4 x Chassis Fan connector(s) (4 x 4 -pin)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x Thermal sensor connector(s)
1 x Power-on button(s)
1 x Reset button(s)
1 x Clear CMOS button(s)
1 x ROG extension (ROG_EXT) header(s)
1 x KeyBot Button
1 x Sonic SoundStage Button
Accessories
User's manual
ASUS Q-Shield
6 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x 12 in 1 ROG Cable Label(s)
1 x ROG Door Hanger(s)
BIOS
64Mb UEFI AMI BIOS, PnP, DMI2.7, WfM2.0, SM BIOS 2.7, ACPI5.0a, Multi-Language BIOS
Manageability
WfM 2.0, DMI 2.7, WOL by PME, PXE
Support Disc
Drivers
ROG GameFirst III
ROG RAMDisk
ROG CPU-Z
ROG Mem TweakIt
Kaspersky® Anti-Virus
DAEMON Tools Pro Standard
ASUS WebStorage
Home Cloud
ASUS Utilities
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note
*1: The PCIe 2.0 x16 slot (PCIEX4_3) shares bandwith with PCIe 2.0 x1 and M.2 slot. The default setting is Auto Mode, which automatically optimizes the system bandwidth. If you install a PCIe 2.0 x4 device, the system will automatically detect and disable PCIe 2.0 x1 and M.2 slot.
*2: The PCIe 2.0 x1 slots (PCIEX1_1/2/3) will be disabled when PCIe 2.0 x16 slot (PCIEX4_3 ) operates under x4 speed or M.2 mode.
*3: The supported functions depends on the CPU installed.
*4: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*5: 1 x USB2.0 ports at mid-board shares with ROG extension (ROG_EXT) port.
Also my ower supply only has 4 pcie connectors and my motherboard has 7 pcie so do I need a different power system? Here are the specs on it.(or what it gives me,not much)
Dimension5.9"(W) x 3.4"(H) X 5.5"(L)
ModularYes
Power750 Watts
80 PlusBronze
ATX Connector1
EPS Connector1
PCI-E Connector4
4 Pin Peripheral Connector6
SATA Connector8
Floppy Connector2
MTBF100,000 hours
Edited by saqib126 - 05 Oct 2014 at 8:05am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 05 Oct 2014 at 9:08am
From your other build post, I believe you mean the gtx 970.   That card requires 2x 6 pin power connectors from the power supply.     The gtx 970 plugs into the Pciex16 slot on the mobo closest to the cpu and then two 6 pin cable  connectors from the power supply harness are run over and plugged into the side of the card for power.  The motherboard and the power supply both are needed.   One for data stuff and the other for power.
Hope this helps. Big%20Smile
  Quote saqib126 Quote  Post ReplyReply bullet Posted: 05 Oct 2014 at 9:12am
So then do I need another motherboard to facilitate the six pin for my gtx970? Also do I need a different power source with 12 pcie connectors to use the 6 pcie on my motherboard and with 2 6pin connectors?
Edited by saqib126 - 05 Oct 2014 at 9:37am
Ariktu View Drop Down
  Quote Ariktu Quote  Post ReplyReply bullet Posted: 05 Oct 2014 at 9:43am
No you do not need another motherboard.
The power supply is what has the 2 6 pin pcie connectors and the cx750 you mention in your build has the 2 you need.
You are fine in the build you have.
Edited by Ariktu - 05 Oct 2014 at 9:44am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 05 Oct 2014 at 9:44am
Nope.  You're good to go.   The 2x six pin isn't the mobo but the power supply.
The Hero mobo can handle only two graphics cards.   The other slots would be for sound card, WiFi card, etc.  A 750W psu can handle the sli, 2x gtx 670 and a sound card and Wifi card get their power off the mobo, where they plug in.
You really have nothing to worry about.  DS has done this a couple of times. Big%20Smile
What Ariktu said.  StrongBig%20Smile
Edited by bprat22 - 05 Oct 2014 at 9:45am
  Quote saqib126 Quote  Post ReplyReply bullet Posted: 05 Oct 2014 at 9:49am
Thank you both!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 05 Oct 2014 at 9:52am
Our pleasure.  Lots to learn. Big%20Smile
This page was generated in 5.078125E-02 seconds.
