Question about Vanquish IIPost Date: 2014-03-29 |
Author | |||
slashx24
Newbie Joined: 29 Mar 2014 Online Status: Offline Posts: 5 |
Topic: Question about Vanquish II Posted: 29 Mar 2014 at 12:56pm |
Okay so I'm saving up for the Vanquish Level 2, and I don't really like the Blue LED So does anyone know what the connectors are for that? I was thinking about buying extra LED Strips+ RGB Color Changing controller for it. So if anyone has any idea of what the connection I should use for the LED please let me know!
After I saved up, and added the LED lighting ill take some pics and put on a light show! :D |
Quote Reply Posted: 29 Mar 2014 at 3:53pm | ||
The led strips have an inverter the lights plug into. The inverter connects to a 4 pin Peripheral connector from the power supply. Within the psu harness behind the right side cover are the 4 pin power coonectors.
Quote Reply Posted: 29 Mar 2014 at 4:59pm | ||
You can buy a separate RGB LED kit and install it yourself. However, keep in mind that the two front fans are Blue LED as well.
slashx24
Quote Reply Posted: 29 Mar 2014 at 7:57pm | ||
Yes I know about that, but i wanted to light up the case more. I looked at reviews and the case isnt well lit so yea. |
saceur
Newbie Joined: 26 Mar 2014 Online Status: Offline Posts: 11 |
Quote Reply Posted: 30 Mar 2014 at 9:20pm | ||
I picked up the lvl 4, is there a way to turn those off? |
Quote Reply Posted: 30 Mar 2014 at 9:24pm | ||
There should be a red switch on the back where you can toggle it on or off. |
saceur
Quote Reply Posted: 30 Mar 2014 at 9:29pm | ||
[/QUOTE]
There should be a red switch on the back where you can toggle it on or off.[/QUOTE] I'll look for it when it arrives. Thanks a bunch |
