Question About overall PreformacePost Date: 2014-12-01 |
LokiReborn
Newbie Joined: 01 Dec 2014 Online Status: Offline Posts: 1 |
Topic: Question About overall Preformace Posted: 01 Dec 2014 at 4:03pm |
Hi Guys,
It's been a while since I've purchased a desktop (usually use business class laptops for work and gaming laptops for personal use) and am purchasing the system bellow, where I don't usually have the option to swap out components other than memory I was wondering where I'm likely to need to upgrade the system in the future when the system is being used for the following: 1)Computer Programming 2)Disassembling Exe files (scanning for viruses etc) 3)Graphic Intensive MMOs in PvP areas i.e. Lots of players & effects Going to be using my 50" in my livingroom as a monitor but am open to any suggestions about good wireless keyboards & mice too as I'd prefer people not tripping over the wires all the time. Configuration Code: 1107320 Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Apollo Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 5820K 3.3GHz (Six-Core) (Unlocked CPU) Motherboard: ASUS X99-DELUXE (Intel X99 Chipset) System Memory: 16GB DDR4 2666MHz Corsair Vengeance LPX (High-Performance) Power Supply: 750W Corsair CX750M Expansion Bay: - No Thanks Optical Drive: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R) Storage Set 1: 1x SSD (512GB Samsung 850 PRO) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 980 4GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 240mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans) Internal Lighting: - No Thanks Airflow Control: Digital Storm Thermal Management Control Board & Software Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) |
Kaelara
Quote Reply Posted: 01 Dec 2014 at 6:18pm |
Looks good I would want a secondary hard drive , but if your short on money you could add that later.
I will not say you will not get a drop in FPS in High player density areas with a lot going on.. I know many players who have 5000$ dollar and higher rigs who see a Drop in the FPS in these areas, but they still should be playable. I tried using my 60 inch flat TV screen as a monitor once.. Maybe my settings were off but I just did not like it. Monitors are the area I am least knowledgeable on.. I usually ask my more computer literate friends for good recommendations. |
Kaelara
Quote Reply Posted: 01 Dec 2014 at 6:55pm |
I use an LG UHD TV as my monitor. The only really issue with using it as a monitor is that the LCD panel isn't right up against the backlight, so the edges seem to float and the very edge is not lit up when up close. Things to make sure of when using a TV as a monitor: put it into a game mode to reduce input latency (this is the same as to what you should do with consoles) and turn off scaling and use a scan mode for the aspect ratio (do not use 16:9, even it your TV is a 16:9 because those modes can crop off the edges for overscanning).
I have a GTX 970 FTW and it plays Assassin's Creed Unity fine at 1080p (high settings) or 2160p (low settings). That game can sometimes render 5000 individual characters in a scene where there are crowds of people. Edited by - 01 Dec 2014 at 6:56pm |
