question about my build
Post Date: 2010-08-25
Ahyi View Drop Down
  Quote Ahyi Quote  Post ReplyReply bullet Topic: question about my build
    Posted: 25 Aug 2010 at 7:42pm
is 1000 psu too much for a dual gtx 480?
  Quote Alex Quote  Post ReplyReply bullet Posted: 25 Aug 2010 at 7:51pm
Nope, it's essential. The GTX 480's are power hungry cards.
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 25 Aug 2010 at 7:55pm
So much so that a 1000w PSU would be pretty strained by two 480s, probably better to grab a 1200w. The 1200w Digital Storm Certified is nicely priced, makes for a good option.
Lilim
Intel Core i7 920 @4.2GHz
Ahyi View Drop Down
  Quote Ahyi Quote  Post ReplyReply bullet Posted: 25 Aug 2010 at 7:59pm
it will be enough to power everything else right?
Motherboard: EVGA X58 LE Edition SLI (Intel X58 Chipset)
Power Supply: 1000W Corsair (Dual/Triple/Quad SLI Compatible)
Hard Drive Set 1: Operating System: 1x (80GB Solid State (By: Intel) (Model: X25-M MLC Edition) (Extreme Performance)
Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology) (EVGA Brand)
Extreme Cooling: H20: Stage 2: Asetek Liquid CPU Cooler HOT SELLER (120mm Radiator) (Great Value)
Benchmarking: - No Thanks
Ahyi View Drop Down
  Quote Ahyi Quote  Post ReplyReply bullet Posted: 25 Aug 2010 at 8:02pm
ehh change that psu to 1200 will that be good for all my components? or shud i get the 1500w one for future needs
!ender_ View Drop Down
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 25 Aug 2010 at 8:04pm
check out the guide in my signature, but short answer is yes 1200w would be good
Ahyi View Drop Down
  Quote Ahyi Quote  Post ReplyReply bullet Posted: 25 Aug 2010 at 9:07pm
so i've heard that the evga le edition runs a little hot sometimes is it true?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 25 Aug 2010 at 9:52pm
can you link anything that says this? i cant find anything
Ahyi View Drop Down
  Quote Ahyi Quote  Post ReplyReply bullet Posted: 25 Aug 2010 at 9:56pm
http://www.ninjalane.com/reviews/motherboards/evga_x58_le/page10.aspx
i read it off here @_@.. oh and whats better stage 2 h20 astek or dh14?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 25 Aug 2010 at 10:07pm
they were testing at 4.5ghz, thats way out of the range you will see on air, or that asetek cooler.
what youre reading there is from the point of view of extreme overclocking, not gaming, they are comparing it to top end boards because even at its low price its capability is through the roof
and as far as whats better, noctua u12p or 14 is pretty much unbeatable unless you go to stage 3 or higher
Edited by !ender_ - 25 Aug 2010 at 10:07pm
Ahyi View Drop Down
  Quote Ahyi Quote  Post ReplyReply bullet Posted: 26 Aug 2010 at 2:43am
okay thank you very much :D going to order this week or next :D
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 26 Aug 2010 at 8:53am
woot Strong
This page was generated in 6.640625E-02 seconds.
