Quad core issue please help!
Post Date: 2009-11-08
JoeThrower123 View Drop Down
  Quote JoeThrower123 Quote  Post ReplyReply bullet Topic: Quad core issue please help!
    Posted: 08 Nov 2009 at 12:49pm
So I have noticed that my computer has been running a lot slower recently. I bought Dragon age origins the other day and have had some really tough issues running the game and my computer is well above the recommended system requirements. It isn't until a just few minutes ago that I was messing around with the settings and saw that it only showed I had 1 Core on my cpu.
How on EARTH did this happen? Are the 3 other cores on my computer messed up? How do I fix this?! Help!
System specs:
System Information
Time of this report: 11/8/2009, 11:45:35
       Machine name: Joe's Computer
   Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.090804-1435)
           Language: English (Regional Setting: English)
System Manufacturer: n/a
       System Model: XFX Nforce 680i Sli
               BIOS: Phoenix - AwardBIOS v6.00PG
          Processor: Intel(R) Core(TM)2 Quad CPU    Q6600  @ 2.40GHz
             Memory: 2046MB RAM
          Page File: 609MB used, 3329MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.5512 32bit Unicode
Display Devices
        Card name: NVIDIA GeForce 8800 GTX
     Manufacturer: NVIDIA
        Chip type: GeForce 8800 GTX
         DAC type: Integrated RAMDAC
       Device Key: Enum\PCI\VEN_10DE&DEV_0191&SUBSYS_C8313842&REV_A2
   Display Memory: 768.0 MB
     Current Mode: 1680 x 1050 (32 bit) (59Hz)
          Monitor: Plug and Play Monitor
  Monitor Max Res: 1600,1200
      Driver Name: nv4_disp.dll
   Driver Version: 6.14.0011.9107 (English)
      DDI Version: 9 (or higher)
Driver Attributes: Final Retail
 Driver Date/Size: 9/27/2009 15:12:22, 5900416 bytes
      WHQL Logo'd: Yes
  WHQL Date Stamp: n/a
              VDD: n/a
         Mini VDD: nv4_mini.sys
    Mini VDD Date: 9/27/2009 15:12:22, 7655872 bytes
Device Identifier: {D7B71E3E-42D1-11CF-6178-3AE803C2CB35}
        Vendor ID: 0x10DE
        Device ID: 0x0191
        SubSys ID: 0xC8313842
      Revision ID: 0x00A2
      Revision ID: 0x00A2
      Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
 Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
         Registry: OK
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
DDraw Test Result: Not run
 D3D7 Test Result: Not run
 D3D8 Test Result: Not run
 D3D9 Test Result: Not run
     Current Mode: 1280 x 1024 (32 bit) (75Hz)
          Monitor: Default Monitor
  Monitor Max Res:
      WHQL Logo'd: Yes
              VDD: n/a
        Vendor ID: 0x10DE
        Device ID: 0x0191
      Revision ID: 0x00A2
      Revision ID: 0x00A2
         Registry: OK
       D3D Status: Enabled
       AGP Status: Enabled
Wink
