PSU and SLI
Post Date: 2014-12-23
Saajuk View Drop Down
  Quote Saajuk Quote  Post ReplyReply bullet Topic: PSU and SLI
    Posted: 23 Dec 2014 at 12:00pm
Just ordered an Apollo here the specs:
System Configuration:
Chassis Model: Special Deal Hot Seller - Digital Storm Apollo
Processor: Intel Core i7 5820K 3.3GHz (Six-Core) (Unlocked CPU)
Motherboard: ASUS X99-DELUXE (Intel X99 Chipset)
System Memory: 16GB DDR4 2666MHz Corsair Vengeance LPX (High-Performance)
Storage Set 1: 1x SSD (250GB Samsung 840 EVO)
Storage Set 3: - No Thanks
RAID Config: - No Thanks
RAID Card: - No Thanks
Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 4GB (Includes PhysX)
HPC Processor: - No Thanks
Chassis Fans: Upgrade Chassis With LED Performance Fans (Blue) (Up to 6 Fans)
Airflow Control: - No Thanks
was wondering if i should get a 850W or 1000W power supply instead of the 750 for the SLI GPUs.
also was wondering if I should upgrade for 40$ to the
H20: Stage 2: Corsair H110 280mm Radiator Liquid CPU Cooler (Extreme-Performance Edition)
over the one I ordered.
thanks!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 12:34pm
The 750 watt psu is fine for your sli 980s.   I would personally go with the EVGA 850 for its much longer warranty but what you have works.
Same for the cpu cooler. The 240mm rad is just fine.
Hope this helps.
Edit... not sure of the warranty on the DS Vortex 240 cooler, but the h100i has a 5 year warranty so that might be a consideration.
Edited by bprat22 - 23 Dec 2014 at 12:39pm
  Quote Saajuk Quote  Post ReplyReply bullet Posted: 23 Dec 2014 at 2:18pm
alright ill stick with what I gots ty
