Please Help!Post Date: 2014-11-25 |
JakeF12
Newbie Joined: 25 Nov 2014 Online Status: Offline Posts: 27 |
Topic: Please Help! Posted: 25 Nov 2014 at 8:04pm |
Hello all, I have been looking to upgrade to a new gaming rig but I really don't know a ton of stuff when it comes to liquid cooled cpu. So I have some question if you wouldn't mind helping me out.
The unit I would like to get is the Aventum and I was wondering what kind of work came related to having liquid in the mix. Refill, how hard is it do and how often..how do you get the right refill liquid. Also I am looking at doing the White case with blue tubing. If I wanted to change the led on the fans and there is 17 fans? Which ones would get the led change. Here is kind of what i'm thinking atm. 1101629 Chassis Model: Special Deal Hot Seller - Black OPS Aventum II Exterior Finish: Pure White Matte Finish with Black Stand Trim Accents: - Not Available Processor: Intel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: ASUS SABERTOOTH Z97 MARK2 (Intel Z97 Chipset) (Military-Grade TUF Components) System Memory: 16GB DDR3 1866MHz Corsair Vengeance Pro (High-Performance) Power Supply: 1050W Corsair HX1050 Expansion Bay: - No Thanks Optical Drive: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Slim Slot Loading Edition) Storage Set 1: 1x SSD (250GB Samsung 840 EVO) Storage Set 2: 1x Storage (1TB Western Digital - Black Edition) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 4GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: HydroLux Level 1: Digital Storm Exotic Custom Cooling System (CPU Only) H20 Tube Color:Blue Tubing with High-Performance Fluid (UV Lighting Reactive) Chassis Fans: Standard Factory Chassis Fans Internal Lighting: Digital Storm RGB LED Lighting System (Requires Thermal Management Control Board & Software) Airflow Control: Digital Storm Thermal Management Control Board & Software Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 Professional (64-Bit Edition) Thanks for any advice. |
Quote Reply Posted: 26 Nov 2014 at 7:19am |
Hi JakeF12.... Welcome to the forums. That's a real nice rig. You could change the 1050hx for a EVGA 850watt psu. Plenty of power for the setup. Nothing wrong with bigger, but the 980's use less juice than the previous generation.
Water cooling setups are usually just topping the fluid off in the reservoir every few months. Easy to do. A full system flush and replacing the fluid might be every year or two, but depends on the usage, etc. Last I heard, DS was using FluidXp, and you can get it from them or online from FrozenPC.com as an example. I can't answer the fan question. Good Luck. Edited by bprat22 - 26 Nov 2014 at 7:29am |
Quote Reply Posted: 26 Nov 2014 at 9:30am |
bprat22 pretty much nailed it. For the LED fan upgrade, it is up to 6 fans. Typically it is the radiator fans or the top fans as the front fans are not visible on the Aventum II.
If you want a specific LED fan, you can leave it in the comment section. Same goes for location of the fans. If you would like more than 6 LED fans you can put that in the comments as well and we can add the extra when processing your order. |
Quote Reply Posted: 26 Nov 2014 at 10:13am |
Hi JakeF12,
That is a nice build. I don't think the Aventum comes with 17 fans unless you choose to equip them all. I think that 17 fan count includes fans on the RADs. I don't own a Aventum so can't say for sure. What monitor or monitors you plan on using and what games you play. Frank Edited by FrankW - 26 Nov 2014 at 10:13am |
JakeF12
Quote Reply Posted: 26 Nov 2014 at 11:19am |
I have two 27" 1920x1080. As far as games I'd like to play everything from Wow to BF4 on max with no issues.
