PhysX FluidMark v1.0.0
Post Date: 2008-08-12
Kelly View Drop Down
  Quote Kelly Quote  Post ReplyReply bullet Topic: PhysX FluidMark v1.0.0
    Posted: 12 Aug 2008 at 1:48pm
PhysX FluidMark is a physics benchmark based on NVIDIA PhysX engine. This benchmark performs a fluid simulation by imitating the renderering of lava. Real physics parameters such as viscosity are used. SPH (Smoothed Particle Hydrodynamics) algorithm is enabled to increase the realism of the simulation.
PhysX FluidMark can run in pure software mode (all calculations are done on the CPU), or in hardware mode. Hardware mode includes 2 kinds of hardware:
Ageia PhysX PPU
GeForce PhysX - GeForce 8/9/GTX200 graphics cards only
This benchmark exploits OpenGL for graphic acceleration and requires an OpenGL 2.0 compliant graphics card: NVIDIA GeForce 5/6/7/8/9/GTX200 (and higher), AMD/ATI Radeon 9600+, 1k/2k/3k/4k (and higher) or a S3 Graphics Chrome 400 series with the latest graphics drivers.
PhysX FluidMark requires NVDIA PhysX drivers 8.08.01 or higher and the CUDA DLL (this DLL has to be copied in the benchmark folder if your Forceware drivers are < 177.79 or if you don't have a GeForce (Radeon, etc.)).
Download : http://downloads.guru3d.com/PhysX-FluidMark-v1.0.0-download-2022.html (Click here)
SLi Rig of the month:
