ODE - H20 TubePost Date: 2014-06-06 |
Seafoam
Topic: ODE - H20 Tube Posted: 06 Jun 2014 at 6:27pm |
Hey guys,
I'm just about to buy a level 4 ODE system. I have one question about one of the configuration options. It asks if I want a 'H20 Tube Color'. Frankly, I have no idea what it is. I believe it's a tube for the liquid cooling, correct me if i'm wrong. I just would like to know what that is, and what the standard color is for the ODE platforms. Thanks, James! Edited by Seafoam - 06 Jun 2014 at 8:43pm |
PC SPECS:
Quote Reply Posted: 06 Jun 2014 at 10:49pm |
The tube color is for when you choose the exotic cooling options with a custom loop. The level 4 uses a 240mm closed loop color that has black tubing that cannot be changed. If you want colored tubing, you're going to have to upgrade to a custom loop.
Seafoam
Quote Reply Posted: 07 Jun 2014 at 8:29am |
Ohh, that makes way more sense. Thanks a bunch!
Also, do you recommend having 2 GTX 780's or 1 780 Ti. I've heard a lot of rumors that dual 780's would draw a lot of power, but still exceed performance. What do you recommend? Edited by Seafoam - 07 Jun 2014 at 8:37am |
PC SPECS:
Quote Reply Posted: 07 Jun 2014 at 9:03am |
The sli 780's will definitely use more juice than a single 780ti. About 150-200 watts more in general. But not really a problem if you go with a 1000w psu. 850watt minimum.
A lot depends on the monitor's resolution you're gaming on. A 1920x1080 monitor will play great with a single 780ti. Even a single 780 is real nice. If you game on a 27" at 2560x1440 monitor, then the sli 780 is needed to max some games. Bacially, for a single 1920x1080 then the 780ti or 780 is just about right. For a higher resolution monitor, the 780ti will still play real nice but not max out some of the heavier shooters, etc. Then sli is needed. |
Seafoam
Quote Reply Posted: 07 Jun 2014 at 9:35am |
I'll be playing on an ASUS 24 inch monitor. (led backlight, 2ms response) Should I upgrade my power supply and go with duals? Or just keep it and go with the Ti, i'm not a heavy gamer but I do use some of the Adobe suite and I expect my graphics to do justice on the Adobe side, rather than the gaming graphics.
PC SPECS:
Quote Reply Posted: 07 Jun 2014 at 9:42am |
I'd stick with a single 780ti.
Seafoam
Quote Reply Posted: 07 Jun 2014 at 10:54am |
Thanks for the response, mate!
Glad there's someone I can trust with computer parts, lol. |
PC SPECS:
