OC x79 plateformPost Date: 2012-06-11 |
tju76
Topic: OC x79 plateform Posted: 11 Jun 2012 at 7:19pm |
Hey guys just started OC my 3820 and from what i have read on other forums they say to disable turbo boost if you are manually OC, i was just wondering if this is true? and why? Thank you
tju76
Quote Reply Posted: 12 Jun 2012 at 5:59am |
just ran prime 95 for 18 hours got my OC back to 4514 mhz at 1.3 vcore gonna mess around with BCLK and multiplyer i want to try and get atlest 4.75, temps all look good nothing even above 70 highest was 67. anyone thinking about getting the 3820 i will tell you it is an easy Overclocker
Hexagonal
Newbie Joined: 08 Jun 2012 Online Status: Offline Posts: 43 |
Quote Reply Posted: 12 Jun 2012 at 6:43am |
Good luck on increasing your OC!
Life holds many Adventures. Buying a New Computer is just One.
Quote Reply Posted: 12 Jun 2012 at 6:47am |
Hi tju76,
Thanks for your comments. DS was doing OK OCing the 3820 and then decided they couldn't do a level 2. From what I have read 4.8 is about tops. I think a 3820 at 4.5 or 4.6 is doable with little effort. Frank |
tju76
Quote Reply Posted: 12 Jun 2012 at 11:07am |
Yeah I think I can get 4.7 hopefully time will tell
