New Vanquish II advicePost Date: 2014-03-12 |
ChaosProdigy
Newbie Joined: 17 Oct 2013 Online Status: Offline Posts: 35 |
Topic: New Vanquish II advice Posted: 12 Mar 2014 at 9:29am |
$1500 Expectations: FPS gaming online Usage: Gaming Special Needs: Quiet, doesn't get too hot Saved Ticket #: [Please Type Here] Specifications: Vanquish ultimate only has 8gb ram which is my only concern here. Anyone has advice in view of my budget and needs? Thank you |
Quote Reply Posted: 12 Mar 2014 at 9:42am |
8Gb ram is all you really need for gaming. If you feel you need more, a custom build like the Marauder or Virtue level 1 allow you to add memory. But a lot more money just to add ram over the pre-built Vanquish. You can always add ram yourself if you were comfortable doing it.
They just unveiled a new Vanquish II lineup. A different case and everything else about the same except level 4 has no unlocked cpu. Hope this helps. |
Theokritos
Quote Reply Posted: 12 Mar 2014 at 10:41am |
If there is any flexibility in your budget, I recommend that you look at what the Slade line offers you. Disclaimer: I recently selected a Slade for myself so there may be some unintended bias toward that model line. The quiet and thermals are two key factors that influenced my decision. |
