New build Questions - SLI or not and other...Post Date: 2015-02-08 |
gleek48
Newbie Joined: 06 Jun 2012 Online Status: Offline Posts: 5 |
Topic: New build Questions - SLI or not and other... Posted: 08 Feb 2015 at 8:06pm |
$2,000-$3,000 Expectations: New PC for High End Gaming and 4K Video Streaming Usage: I want my next computer to play the new games at a faster FPS Special Needs: I have a i5-3570k with a GTX 670 FTW and was wondering how much faster this new setup would be? My current setup actually seems to be holding up ok, with a PC Mark 7 score of around 5800. Also, for high end gaming (fast FPS) and 4 K video streaming, would 2 GTX 970's be significantly better than 1 GTX 980 for gaming and 4K video? Saved Ticket #: 1145802 Specifications: Chassis Model: Special Deal Hot Seller - Corsair Obsidian 550D Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i5 4690K 3.50 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: GIGABYTE G1.Sniper Z97 (Intel Z97 Chipset) (Onboard Creative Sound) System Memory: 16GB DDR3 1866MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 850W EVGA SuperNOVA Expansion Bay: - No Thanks Optical Drive: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST) Storage Set 1: 1x SSD (250GB Samsung 850 EVO) Storage Set 2: 1x Storage (2TB Western Digital/Seagate/Hitachi) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 970 4GB (EVGA ACX Cooler Edition) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 240mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: Noise Suppression Package Stage 1 (Optimized Airflow & Fan Speeds Only) LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: Yes, Disable and tweak all of the non-crucial services on the operating system Windows OS: Microsoft Windows 8.1 Professional (64-Bit Edition) Edited by gleek48 - 08 Feb 2015 at 8:12pm |
Quote Reply Posted: 09 Feb 2015 at 5:15am |
Hi gleek48... That's a real nice build. As far as performance increase over what you have, a single 970 will give you a significant boost over your 670. Here's a link to compare..... http://www.anandtech.com/bench/product/1349?vs=1355
You can also use the link to swap to other cards to compare. The 970 is only about 10-15% behind the 980 so sli 970 is a big boost over single 980. Whether you need sli 970 or not depends on the monitor's resolution and you expectations. If you want all games to run on Ultra and stay at 60fps or better on a single 1080p, than that's where the added card helps. If you're gaming on 4K then the sli 970 would be a minmum. Most of your gaming performance increase will be with the gtx 970. Your cpu is still very good. I can't speak of streaming. Never looked into it. Hope this helps and good luck. FYI.. If your picking the 550D Slade for the best in quiet, which a lot do, then the 240mm rad will mount under the top and require the top acoustic panel to remain off for the rad fans to exit the heat. Some of the quiet goes away. The advantage of the 240 mm rad on top is increase case airflow. Edited by bprat22 - 09 Feb 2015 at 5:24am |
gleek48
Quote Reply Posted: 09 Feb 2015 at 8:43am |
Would the standard 120mm water cooled setup improve the sound level while keeping it cool? Thanks! |
Quote Reply Posted: 09 Feb 2015 at 8:47am |
Yep. The 120mm rad would mount inside the back where the exit fan is now and give you very good cooling for the stage 1 overclock. And, it allows the top acoustic panel to stay on. It would be quieter.
