MMO Config Advice
Post Date: 2012-06-16
Taiki View Drop Down
  Quote Taiki Quote  Post ReplyReply bullet Topic: MMO Config Advice
    Posted: 16 Jun 2012 at 9:11am
Hello.  I'm looking at getting a new system for my girlfriend and I to play MMOs together.  Our current systems are getting pretty old and we have to play on the lowest settings possible.  Even with the settings so low we still tend to lag some on raids and PVP.
Hers: $1,500 - $2,500
Mine: $2,000 - $3,500
We want to be able to play present and near future MMOs on high settings without video lag.  This is especially important for raids and PVP.  I plan to buy each of us a Dell UltraSharp U2410 (1920x1200).
Strictly MMOs (SWTOR, GW2) with minimal internet use.
Are any of the sound cards worth the money or have the internal sound cards come a long way?
I don't mind spending money for a great system, but I don't want to overspend on things I don't need.  I remember reading configs awhile ago about asking DS for a vcore of 1.4 and additional fans for the HAF X case?  Also is the i5 better for MMOs than the i7 and is it worth extending the warranty past the standard 3 years?
This is a build I'm looking at for one or both of us.  One last note, our systems don't have to be the same since I'm willing to spend more than she is Big%20Smile.
Thanks for the help!
Saved Ticket #: 699563
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Small)
  Quote FrankW Quote  Post ReplyReply bullet Posted: 16 Jun 2012 at 9:41am
Hi Taiki,
That is a pretty solid build. I don't know if I would change anything. You are setup for SLI 670 in the future.
If it was my system I would go with the 3770 to get the HT feature. It is not needed for todays games but what happens if a new game comes out that uses HT and you don't have it. Windows does use HT and Win-8 may even take more advantage of it. I don't know?
I think extending the warranty on any gaming computer is a smart move. The 3 year DS warranty only provides one year on parts. You will have to decide if a longer warranty is important to you.
The second 200mm fan at the top does help with cooling. It particular helps to evacuate the warm air coming from the front part of the case. With only one GPU I don't know if you really need it or if it is just nice to have.
Edited by FrankW - 16 Jun 2012 at 1:07pm
Orange7 View Drop Down
  Quote Orange7 Quote  Post ReplyReply bullet Posted: 16 Jun 2012 at 12:44pm
I agree with everything FrankW said, but I think that I need to add that your surroundings will greatly influence CPU stresses. In areas with smaller numbers of players, there will be less CPU usage, because the main task of the CPU is manipulating positional data. Therefore, if you spend your time with a few friends in areas with few other players, even a low level CPU could work for gaming. However, if you plan on spending a lot of time in areas like Dalaran, you should go for a much higher end CPU.
DS xm15 Stage 4
i7-3820 (2.7GHz/3.7GHz)
16GB 1600MHz DDR3
GT 630, 1GB
240GB Intel 520
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 16 Jun 2012 at 2:19pm
Frank and Orange7 have this covered.   My only thought is that the vcore at 1.4 or less I don' t believe with the Ivy Bridge chip means as much.     The Ivy Bridge oc higher with less voltage.    But, doesn't hurt to ask.
  Quote Taiki Quote  Post ReplyReply bullet Posted: 16 Jun 2012 at 2:51pm
FrankW: I'll have to think about the 3770 for possible future game as you pointed out.
Orange7: We usually try to avoid the highly populated areas but sometimes in PVP and raids that's not possible.  When you say we should consider a much higher end CPU which one do you suggest?
bprat22: Good to know about the vcore settings and Ivy Bridge.
Thanks a bunch for the help guys, I really appreciate it!
  Quote Orange7 Quote  Post ReplyReply bullet Posted: 16 Jun 2012 at 3:42pm
I don't think that your choice would matter much now (Either would probably be fine). As FrankW said, it is more about future-proofing it, and the 3770 would probably be better for that, primarily due to the larger L3 cache.
DS xm15 Stage 4
16GB 1600MHz DDR3
GT 630, 1GB
240GB Intel 520
kaldoot View Drop Down
  Quote kaldoot Quote  Post ReplyReply bullet Posted: 16 Jun 2012 at 4:38pm
MMOs by design are made to appeal to mass markets and will never have steep requirements.
You are building a true GAMING PC here, either i5 or i7 is going to smoke these games. Ofc, future proofing is never a bad thing. But expect MMOs to be not effected by either processors for a long foreseeable future though.
benchmarked here"
http://www.tomshardware.com/reviews/star-wars-gaming-tests-review,3087.html
  Quote Taiki Quote  Post ReplyReply bullet Posted: 17 Jun 2012 at 10:06am
Thanks Orange7 and kaldoot.  I'm definitely looking for a system config that will allow me to play on high settings for current and next-gen MMOs.  So future proofing will probably be worth the extra money.
This page was generated in 9.423828E-02 seconds.
