Missing clocks
Post Date: 2012-12-12
Scharf19 View Drop Down
  Quote Scharf19 Quote  Post ReplyReply bullet Topic: Missing clocks
    Posted: 12 Dec 2012 at 2:26pm
Hey everyone! I got my Hailstorm in May. It is the 3960x at 3.3 ghz.. I overclocked it to 4.5.. The last three weeks it shuts off and goes to blue screen of death.. With something the effect of missed clock.. It's been happening once a day now.. Sucks when I am filming Dayz footage.. Please help?! Should I bring it back to the 3.3? Will I notice a difference?? I really appreciate it guys.. Thanks!
tju76 View Drop Down
  Quote tju76 Quote  Post ReplyReply bullet Posted: 12 Dec 2012 at 2:33pm
Missed clock means a unstable oc what voltage are you using to get 4.5
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Dec 2012 at 2:36pm
Hi Sharf19...     Not sure of the message with BSOD, but you could go to Bios and load default proflie, F5 usually and F10 to save and exit.     If this fixes it, call DS and they will help you tweek overclocking, possibly adjusting the voltage just a bit.
Ram sticks being faulty can also mess with oc'ing.    Try reseating the ram sticks.
Good luck.
  Quote Scharf19 Quote  Post ReplyReply bullet Posted: 13 Dec 2012 at 6:38pm
Sorry guys in the Army, and I barely get free time.. It's been forever since messing with it...
Voltage INFO
Current CPU VCore 1.325
Current DImm 1 and 2 Voltage 1.493
Current Dimm 3 and 4 Voltage 1.498-1.500
Current VCCIO 1.058
Current PCH Voltage 1.104
Voltage Health
+12V   12.160
3VSB    3.296
VBAT   3.328
VCC 3.3V   3.312
COU PLL Voltage Control 1.792
Then if you don't see anything bad ill go to default..
I appreciate it guys!!
  Quote tju76 Quote  Post ReplyReply bullet Posted: 13 Dec 2012 at 8:06pm
Try bumping your vcore up in small incriments and run a stress testing prrogram like intel burn test or prime95 have you made any changes to your system diff ram etc
  Quote Scharf19 Quote  Post ReplyReply bullet Posted: 13 Dec 2012 at 10:38pm
Nope, no changes.. going to try vcore now
  Quote Scharf19 Quote  Post ReplyReply bullet Posted: 18 Dec 2012 at 12:30am
I just brought it back to the 3.3 ghz.. No errors anymore.. but I definitely can tell the slow down in some games... Is there away someone could help me over clock this???
  Quote tju76 Quote  Post ReplyReply bullet Posted: 18 Dec 2012 at 9:16am
Did you try raising the voltage like I said ? Oc is a process raise the voltage stress test and see if it is stable if not then repeat
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 18 Dec 2012 at 9:47am
I know your time is tight, but I would suggest getting DS on the phone and having them help you tweek the oc.  Plus, less chance of losing the warranty by doing it yourself.
