Memory upgrade for Vanquish 2 Lvl 4
Post Date: 2015-03-17
beckmabj View Drop Down
  Quote beckmabj Quote  Post ReplyReply bullet Topic: Memory upgrade for Vanquish 2 Lvl 4
    Posted: 17 Mar 2015 at 9:35pm
Hey guys first let me start off saying i love this machine. Had it for awhile now and couldn't be happier. This may be a stupid question but I'm thinking about upgrading the memory to 16gb and I'm not quite sure what to look for. I found this and was wondering if it would work http://www.newegg.com/Product/Product.aspx?Item=N82E16820231558
Any tips or suggestions on different memory would be appreciated too.
Thanks guys!
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 17 Mar 2015 at 10:24pm
Is it worth it? Only if you are running out of memory on a normal basis. You'd notice a dramatic decrease in responsiveness in the system if you're running out of memory and the O/S begins paging information on your SSD. This happens if you have many tabs in a browser open, many intensive programs open, large video or photo editing projects going on, multiple virtual machines, or any combination of them or other memory consuming things going on. If that's happening, it is up to you whether it is worth it or not.
  Quote beckmabj Quote  Post ReplyReply bullet Posted: 18 Mar 2015 at 4:24am
Yeah its worth it for my situation could you tell me if that memory would work or if there is a better memory option?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 18 Mar 2015 at 5:39am
According to their website, the Z97x-sli mobo is compatible.  Strong  I figured it would be, but checked just to see what it said.
http://www.gskill.com/en/product/f3-1600c10d-16gao        Look under the QVL tab.
Good Luck. Big%20Smile
