Looking for insight on some upgrades for gamingPost Date: 2014-11-18 |
grave17
Newbie Joined: 05 Nov 2012 Online Status: Offline Posts: 39 |
Topic: Looking for insight on some upgrades for gaming Posted: 18 Nov 2014 at 2:47pm |
Below are my current specs I'm starting to see a bit of a strain with my current rig and would like to start pricing and look at good upgrades for performance. Mainly I play recent games an see the chug such as in Dragons Age Inquisition, CoD AW at max settings on both and the new Far Cry 4. I'm thinking realistically all I have to do is switch out my 670 ftw for a 970 but if this thought process is wrong im open to better informed suggestions. Any all advice is appreciated thanks in advance
System Configuration: Chassis Model: Special Deal Hot Seller - Corsair Carbide 400R Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i5 3570K 3.40 GHz (Unlocked CPU) (Quad Core) Motherboard: ASUS P8Z77-V LX (Intel Z77 Chipset) (Does Not Support SLI) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 800W Corsair GS (Dual SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (1TB Western Digital/Seagate/Hitachi/Samsung (7200 RPM) (32MB Cache) <b></b> Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: !CLEARANCE: 1x (120GB Solid State (By: Corsair) (Model: Force GT Series) (SATA 6Gbps) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card(s): 1x NVIDIA GeForce GTX 670 2GB (PhysX) (FTW Overclocked EVGA) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 1: Cooler Master Hyper 212 EVO (High Performance Cooler) H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Edited by grave17 - 18 Nov 2014 at 3:00pm |
Quote Reply Posted: 18 Nov 2014 at 4:18pm |
Hi grave17... You nailed it. All you need is the graphics card upgrade and the gtx 970 will give a huge boost. Between a 50% and double fps increase, game dependant.
Good luck and let us know how it goes. |
grave17
Quote Reply Posted: 18 Nov 2014 at 5:44pm |
seeing as there are multiple 970's is any version in particular the best purchase choice I don't mind paying a bit more performance
Quote Reply Posted: 18 Nov 2014 at 5:59pm |
A high performance card that is rather quiet is the GTX 970 FTW, but from what I've heard, they are hard to find in stock. Another card to look for is the Galaxy GTX 970 Hall of Fame, which has the highest factory clock out there; don't know the availability of it though.
Quote Reply Posted: 18 Nov 2014 at 7:02pm |
it currently in stock on the Amazon site
grave17
Quote Reply Posted: 22 Nov 2014 at 2:57pm |
So I am about to finalize my purchase with this card will I have any issues with how it fits or anything? I believe I wont but another pair of eyes just to be sure would be appreciated.
http://www.amazon.com/Gigabyte-GeForce-Graphics-GV-N970G1-GAMING-4GD/dp/B00NH5T1MS Edited by grave17 - 22 Nov 2014 at 2:58pm |
Quote Reply Posted: 22 Nov 2014 at 4:59pm |
the length of the card is 12.28'' inches and the maximum card length that can fit in that case is 12.52'' so i don't think you should have any issues
Edited by ArkansasWoman777 - 22 Nov 2014 at 5:00pm |
