Liquid CoolingPost Date: 2012-05-28 |
seanm
Newbie Joined: 27 May 2012 Online Status: Offline Posts: 6 |
Topic: Liquid Cooling Posted: 28 May 2012 at 8:24pm |
Ok, so at what point can you start justifying liquid cooling on graphics cards and chipset? I understand just the cpu, but how about everything else?
Is it based on: 1. How long you keep the rig running? 2. How far you have everything overclocked? 3. How long you want it to last? (liquid cooling = greater longevity at higher levels) I know DS will take care of it in any build I make and let me know, but I'm just curious at this point lol. |
surf71zx
Groupie Joined: 07 Jan 2011 Online Status: Offline Posts: 485 |
Quote Reply Posted: 29 May 2012 at 7:21am |
The chipset and cpu should go together for liquid cooling if your going to overclock as the ultimate cooling solution. The gpu is another story. Everbodys perception of noise is different.Whats loud to one person is quiet to another.Case selection plays a big factor.Some are designed for liquid cooling ,while others lean more to air cooling quietness.If you use headphones an air cooled case will be just fine.If you have a sound system your plugging in and you dont want to here them gpus sound loud like turbines ,go liquid for the quiet effect.Your still going to have some fan noise from case fans and radiator fans.You have to counter act that noise with quiet custom fans from a number of vendors.It all depends on how much money you want to spend and what road you take on how quiet you want your computer. There is a plus side to gpu liquid cooling with longevity and higher overclocks.
