Liquid Cooled Xbox 360
Post Date: 2008-12-05
jtspectra2 View Drop Down
  Quote jtspectra2 Quote  Post ReplyReply bullet Topic: Liquid Cooled Xbox 360
    Posted: 05 Dec 2008 at 6:01pm
Q9650 @ 4.2Ghz( Liquid Cooled), 4GB 1600Mhz DDR3, GTX280 SLI, VRaptor,HAF 932
XpubuX View Drop Down
  Quote XpubuX Quote  Post ReplyReply bullet Posted: 05 Dec 2008 at 7:11pm
This will void youre warranty on the xbox but may be worth it once the 3 year warranty is up.
MikeMaravani View Drop Down
  Quote MikeMaravani Quote  Post ReplyReply bullet Posted: 09 Dec 2008 at 11:59am
Well, in 3 years they just might have a new system coming out. There is talk on the web...
MarkNY View Drop Down
  Quote MarkNY Quote  Post ReplyReply bullet Posted: 11 Dec 2008 at 11:11am
what is the point of that? can you OC an xbox 360 a ton with liquid cooling?  is there any noticeable difference with game play?
White Aventum
3970X at 4.7Ghz
Asus Rampage IV Extreme
16 GB 2400MHz Memory
2x Nvidia Classified 680 4GB
2x 240 GB Neutron SSD
1x 1 TB WD Caviar
Liquid Cooled CPU/GPU/Chipset
  Quote jtspectra2 Quote  Post ReplyReply bullet Posted: 11 Dec 2008 at 8:29pm
no , but the 360 is loud as hell, im assuming it would take away from some loudness , also it keeps the CPU cooler . :D
its just something cool for us tech savvy people .
Rad!caL View Drop Down
  Quote Rad!caL Quote  Post ReplyReply bullet Posted: 11 Dec 2008 at 10:19pm
But now you can just load games on your HD so half the sound is gone without the DVD drive spinning.
  Quote MikeMaravani Quote  Post ReplyReply bullet Posted: 12 Dec 2008 at 12:10pm
Thats true. I want to buy the Ultimate 360. Then I will do all the little tech projects.
Onkel_Ken View Drop Down
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 13 Mar 2009 at 12:52am
I think the xboxs are getting better.  But my grandkid had one that died right after the warranty went out.
HAF 932/920 OC 3.60/V8
6GB 1333Mhz
HP w2408h Vivid Color/WS
