Lance Laptop?Post Date: 2014-06-15 |
Fez73
Newbie Joined: 15 Jun 2014 Online Status: Offline Posts: 2 |
Topic: Lance Laptop? Posted: 15 Jun 2014 at 9:27pm |
I need a new gaming laptop to replace my old Alienware M17x R2. Not only is my Alienware now 4 years old, but it has always been a bit too heavy and cumbersome when traveling. So, to lessen the back pain, I'm looking at a Lance with the 8GB 880M card.
When I'm home I typically plug my laptops into an external monitor and set them on a laptop cooler. Currently, I have a 4k Samsung monitor. I don't necessarily need to run at 4k when gaming, but it would be nice to have the capability if the 880M can handle it. Currently my Alienware AMD 5870M cards get so hot when gaming that I'm fairly limited (probably a case where I need to reapply thermal paste and do some internal cleaning, but the laptop is getting outdated all the same. So, can the Lance give me what I need? Solid gaming in a smaller package? Thanks for the advice. |
Fez73
Quote Reply Posted: 16 Jun 2014 at 5:01pm |
Anyone have a Lance laptop? Doesn't seem like my message is garnering any responses as of yet.
Quote Reply Posted: 16 Jun 2014 at 5:40pm |
There definitely are people who have the Lance, but I'm guessing they slipped passed this thread.
The GTX 880M is a very capable card and is the equivalent of a full desktop GTX 770 in terms of performance. Should give you the performance you are looking for without burning you in the process. |
Roykirk
Quote Reply Posted: 17 Jun 2014 at 10:03am |
I don't have the Lance, but the larger Krypton with the 880M. I'm not sure of the difference in thermals since the form factor is smaller, but I can tell you the Krypton runs cooler than any gaming laptop I've had so far. Heat is well-directed out of the back ports and my keyboard doesn't heat up like on past units from other vendors. I have an active laptop cooler that it rests on, but I've never needed to turn on the fans to cool it.
Since the Lance appears to have a Clevo case with a similar design to the Krypton, I suspect you'll have similar results, but couldn't say for sure. I would think if the Lance has the same DisplayPort and mini-DP outputs of the Krypton, you'll have no trouble driving a 4K monitor, but again, I don't have a 4K monitor, so can't say for sure. Come on, Lance owners, let's hear your thoughts! |
