Impossible buildPost Date: 2014-09-21 |
Farmall200
Newbie Joined: 28 Aug 2014 Online Status: Offline Posts: 6 |
Topic: Impossible build Posted: 21 Sep 2014 at 9:11am |
1300 (excluding shipping) Expectations: It's a digital storm... That says it all. Usage: 3d modeling, server hosting, gaming, rendering, school work Special Needs: Not to many, would prefer an i7, but will accept an i5 if it's needed by the budget, also would like a 900 series card, or at the very least a nividia. They are the best for 3d modeling. Thanks! |
Signature? Who uses those anymore?
Farmall200
Quote Reply Posted: 21 Sep 2014 at 9:14am |
Forgot to add, already have a monitor, keyboard/mouse. Do need an operating system
Gunlord
Groupie Joined: 23 Jun 2013 Online Status: Offline Posts: 187 |
Quote Reply Posted: 21 Sep 2014 at 9:46am |
Hmm...well if you'd be happy with an i5 and Nvidia, you could start off with a look at the Vanquish Lvl. 3, which is well below your budget at 979 dollars:
https://www.digitalstormonline.com/configurator.asp?id=995475 It's got: - NVIDIA GTX 760 2GB - Intel Core i5 4590 CPU - 8GB 1600MHz Memory - 1TB 7200RPM HDD - ASUS H81 Chipset Motherboard - 600W Corsair CX Power Supply - DVD-R/RW/CD-R/RW - Microsoft Windows 8.1 I was also able to configure a cool Virtue at 1252$ for you with a Nvidia 970 graphics card, but it has an AMD processor (I couldn't find an option for an Intel processor): https://www.digitalstormonline.com/configurator.asp?id=1052433 Edited by Gunlord - 21 Sep 2014 at 9:47am |
Farmall200
Quote Reply Posted: 21 Sep 2014 at 10:13am |
Thanks for the options, im going to up it to 1400, to see if some intel cpu's can start to filter in
Ariktu
Quote Reply Posted: 21 Sep 2014 at 11:02am |
if I was you I would find a way to get the vanquish level 4 as soon as the GTX 970 gets tossed into the system build since the GTX 770 is being discontinued it should happen soon.
Quote Reply Posted: 22 Sep 2014 at 11:27am |
I agree with Ariktu, if you can wait you are best off by waiting for the GTX 970s to hit the Vanquish level 4.
