HydroLux Level???
Post Date: 2015-03-10
suisse78 View Drop Down
  Quote suisse78 Quote  Post ReplyReply bullet Topic: HydroLux Level???
    Posted: 10 Mar 2015 at 6:39pm
HydroLux Level in this photo? CPU Only or CPU + Chipset?
Thank You
Marco
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 10 Mar 2015 at 7:19pm
CPU only...The GPUs there have the reference NVIDIA blower and heatsink on them. You can see that none of the coolant tubes lead to either of the video cards.
Here's a pick with GPU water cooling:
  Quote suisse78 Quote  Post ReplyReply bullet Posted: 11 Mar 2015 at 12:58am
http://youtu.be/AmDoC2NxpP8
The Apollo who is here in this video what characteristics? Hydrolux level, Fans, Color tube?
I would like to order it like this computer
Thank you.
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 11 Mar 2015 at 8:38am
Here's the closest you can get:
Configuration URL:     https://www.digitalstormonline.com/configurator.asp?id=1161356
Chassis Model: Special Deal Hot Seller - Digital Storm Apollo
Motherboard: ASUS SABERTOOTH Z97 MARK2 (Intel Z97 Chipset) (Military-Grade TUF Components)
System Memory: 16GB DDR3 1866MHz Corsair Dominator Platinum DHX (Extreme-Performance)
Power Supply: 1050W Corsair HX1050
Optical Drive: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST)
Storage Set 1: 2x SSD (250GB Samsung 850 EVO)
Storage Set 2: 2x Storage (2TB Western Digital - Black Edition)
Storage Set 3: - No Thanks
RAID Config: RAID 1: Mirroring: Drive Failure Data Fault Tolerance Protection (Requires 2 HDDs)
RAID Card: - No Thanks
Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 4GB (Includes PhysX)
HPC Processor: - No Thanks
Extreme Cooling: H20: HydroLux Level 1: Digital Storm Exotic Custom Cooling System (CPU Only)
H20 Tube Color:Blue Tubing with High-Performance Fluid (UV Lighting Reactive)
Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans)
Airflow Control: - No Thanks
Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires High-End Motherboard Selection)
Portable Gaming: - No Thanks
Branded Gear: - No Thanks
This page was generated in 2.734375E-02 seconds.
