Help with Config for Business ComputerPost Date: 2011-04-16 |
rosevilleca
Newbie Joined: 16 Apr 2011 Online Status: Offline Posts: 1 |
Topic: Help with Config for Business Computer Posted: 16 Apr 2011 at 4:00pm |
Hello,
I am looking for suggestions on either a new configuration or suggestions for modifications to the one below. I am looking for a computer that is quiet, small footprint, and is able to accomodate 20 simultaneous windows open in a internet browser, with Adobe Acrobat and Excel and Word useage.
I never want to have to wait on my computer, but I want the computer to be always waiting for me to make keyboard inputs. I don't play any games, but I want a graphics card that is at least able to play modestly, a few games here and there, maybe WOW on a 30" screen. I will hardly ever be playing games.
Hope you will make some suggestions for a configuration for a computer!
Total Price with Instant Savings: $2,461.00
Direct Load URL: http://www.digitalstormonline.com/comploadsaved.asp?id=523497 Specifications: Chassis Model: Special Deal Hot Seller - Black OPS Enix Edition Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 2600K 3.40GHz (Unlocked CPU for Extreme Overclocking) (Quad Core) Motherboard: ASUS P8P67-M PRO (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue) System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair TX (Dual SLI Compatible) Expansion Bay: External USB Digital Media Card Reader Hard Drive Set 1: Operating System: 1x (250GB Solid State (By: Intel) (Model: 510 Series SSDSC2MH250A2K5) (Extreme Performance) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Slim Slot Loading Edition) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 550 Ti 1GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: Standard Factory Heat-sink and Fan (Not Recommended for CPU Overclocking) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: FREE: Overclock the processor between 3.6GHz to 3.9GHz Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery |
ablahblah
DS Veteran Joined: 12 Jun 2009 Online Status: Offline Posts: 2312 |
Quote Reply Posted: 16 Apr 2011 at 7:14pm |
- I must have over 20 tabs or more open in Firefox on a daily basis, and I rarely will go over 3GB usage....ehehe
- That's going to one BLAZING fast office computer...just fyi...kind of overkill if you ask me if it's just for office haha. - 250GB SSD? My recommendation is a 120GB Intel 320 series SSD, controller's had a better legacy and reputation, and it should be more than enough. Having a bigger capacity SSD is pointless if you really don't need to put that much on it, I'm not sure what'll be good to load up on that much space. - Overclocking on stock coolers isn't recommended in my opinion. IMHO, a H70 is probably all you need, and it accommodates that case's form factor well. Larger coolers will fit, but I dunno, it just looks odd and I think since smaller cases like that are more prone to shifting, it's not too good of a choice. Edited by ablahblah - 16 Apr 2011 at 7:16pm |
R4D4RPR00F
Core i7 920 @ 3.9Ghz Asus Sabertooth X58 EVGA GTX 570 Mushkin 6GB 1414Mhz |
DST4ME
Quote Reply Posted: 17 Apr 2011 at 2:06am |
I have over 50 taps open at any given time, but which browser you use makes a difference also, chrome for example is the worst, and uses crazy amount of ram.
Here you go Ticket# 523778 --- $1991 (To see this build click here) Copy of Specifications: Chassis Model: Special Deal Hot Seller - HAF 922 Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 2600K 3.40GHz (Unlocked CPU for Extreme Overclocking) (Quad Core) Motherboard: ASUS P8P67 (Intel P67 Chipset) (New B3 Revision) (Does Not Support SLI) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair TX (Dual SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Intel) (Model: 320 Series SSDSA2CW120G3K5) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 560 Ti 1GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 1: Noctua NH-U12P SE Dual 120mm Fans High Performance Cooler H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: Stage 1: Overclock the processor between 4.0GHz to 4.5GHz (Cooling Upgrade Recommended) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty 90% of your noise will come from the gpu's fan while under load. your HDD setup should be: HDD1 = fast small drive: os/apps/games HDD2 = regular large drive: media/personal/work file storage |
Quote Reply Posted: 01 Apr 2014 at 12:14pm |
This was posted in 2011..... |
Eggy
Quote Reply Posted: 01 Apr 2014 at 12:34pm |
Sweet thread resurrection. How bout that 1GB GPU!
Quote Reply Posted: 01 Apr 2014 at 12:59pm |
Pretty sure the JohnVick account was a bot, i've seen that "krojam" posted here before by another account with 1 post.
Quote Reply Posted: 01 Apr 2014 at 3:48pm |
I missed the bot! -_- Not cool... I always miss all the fun.
Quote Reply Posted: 01 Apr 2014 at 3:51pm |
Poor Meller!!! Lol |
