Having second thoughts...Post Date: 2014-02-12 |
tallikat
Newbie Joined: 10 Feb 2014 Online Status: Offline Posts: 19 |
Topic: Having second thoughts... Posted: 12 Feb 2014 at 8:51pm |
$1500-$2800 Expectations: I had already settled on my final build here #925860, but while waiting for my tax returns, the extra time has me second guessing myself. Basically I want be able to play today's games and any games for the next two years @ 1080p smoothly on ultra. So I just want the barebones minimum to get the job done for now, and then upgrade a couple years from now. I have the $2800, but I'd rather just spend the $1500 for now. But anything in between is just as well. I'm just really getting into PCs, so I don't know what mid range components to use to get the job done. Any suggestions would be greatly appreciated. Thanks Usage: Gaming, web, a little multimedia Special Needs:ultra settings @ 1080p for a couple years Saved Ticket #: 925860 Specifications: [Please Type Here] |
tallikat
Quote Reply Posted: 12 Feb 2014 at 9:11pm |
Chassis Model:Special Deal Hot Seller - Digital Storm Marauder V2
More Info Exterior Finish:- Standard Factory Finish Trim Finish:- Standard Factory Finish Core Components Processor:Intel Core i7 4770K 3.50 GHz (Unlocked CPU) (Quad Core) More Info Motherboard:ASUS Sabertooth Z87 (Intel Z87 Chipset) (Features Thermal Armor and Thermal Radar) More Info System Memory:16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) More Info Power Supply:850W Corsair RM More Info Storage / Connectivity Expansion Bay:- No Thanks Optical Drive:ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST) More Info Storage Set 1:1x (128GB Solid State (By: Samsung) (Model: 840 Pro Series) More Info Storage Set 2:1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) More Info Storage Set 3:- No Thanks RAID Config:- No Thanks RAID Card:- No Thanks Internet Access:High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) More Info Graphics / Audio / HPC (Super Computing) Graphics Card(s):1x NVIDIA GeForce GTX 780 Ti 3GB (EVGA Superclocked ACX Cooler Edition) More Info Sound Card:Integrated Motherboard Audio More Info HPC Processor:- No Thanks Digital Storm Engineering Lab Extreme Cooling:H20: Stage 2: Corsair H100i 240mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) More Info H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Airflow Control:- No Thanks Internal Lighting:- No Thanks Chassis Fans:Upgrade Chassis With LED Performance Fans (Green) (Up to 6 Fans) More Info Chassis Mod's:- No Thanks Noise Reduction:- No Thanks LaserMark:- No Thanks Digital Storm TwisterBoost Technology CPU Boost:Stage 1: Overclock CPU 4.0GHz to 4.4GHz More Info Graphics Boost:- No Thanks, Please do not overclock my video card(s) Memory Boost:- No Thanks, Please do not overclock my memory OS Boost:- No Thanks, Please do not tweak the services on the operating system Software Windows OS:Microsoft Windows 8.1 (64-Bit Edition) More Info Recovery Tools:Windows Recovery Toolkit (Bundled with Windows CD) More Info |
Quote Reply Posted: 12 Feb 2014 at 9:24pm |
That's a great setup. The Power supply is a little much for your build but it gives you headroom in case you want to run SLI in the future.
The GTX 780Ti is indeed the most powerful gaming card out at the moment and will definitely run most games to come on Ultra at 1080P. |
tallikat
Quote Reply Posted: 12 Feb 2014 at 9:47pm |
Yeah down the road I definitely would like to add a second card down the road, 4k will be the norm eventually, so I wanna plan ahead so when the prices on the displays come down I'll be good to go.
Quote Reply Posted: 13 Feb 2014 at 2:36am |
That's an excellent build with quality parts. And, room to grow if ever needed. Congrats.
Quote Reply Posted: 13 Feb 2014 at 3:43am |
Looks like a very solid build to me. Though, if you are thinking of the second 780 Ti, that power supply would be on the low side. I would suggest bumping it to a 1000W range one.
tallikat
Quote Reply Posted: 13 Feb 2014 at 5:17am |
Yea I'll probably go back to the 1050, was trying to save a few bucks but I prefer the longevity
fstcvc
Quote Reply Posted: 13 Feb 2014 at 8:03am |
Agree on PSU - go with either the 1000W SilverStone or 1050W Corsair for dual 780ti's.
Great looking build otherwise!! |
HailStorm II
tallikat
Quote Reply Posted: 18 Feb 2014 at 5:38pm |
so this is what i finally ordered. stage 1. came in about $40 under my max budget. pretty darn happy with it. especially just finding out my wife's 4 year old dell insirion laptop can actually play a fair amount of decent games on steam. enough to hold me over during the wait.
Chassis Model: Special Deal Hot Seller - Digital Storm Marauder V2 Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4770K 3.50 GHz (Unlocked CPU) (Quad Core) Motherboard: ASUS Sabertooth Z87 (Intel Z87 Chipset) (Features Thermal Armor and Thermal Radar) System Memory: 16GB DDR3 1866MHz Corsair Vengeance Pro (High-Performance) Power Supply: 1050W Corsair Pro Silver 1050HX (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Optical Drive: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST) Storage Set 1: 1x (128GB Solid State (By: Samsung) (Model: 840 Pro Series) Storage Set 2: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 780 Ti 3GB (EVGA Superclocked ACX Cooler Edition) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 240mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) <b></b> H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Upgrade Chassis With LED Performance Fans (Green) (Up to 6 Fans) Internal Lighting: Internal Chassis Lighting System (Green) Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Graphics Boost: - No Thanks, Please do not overclock my video card(s) Memory Boost: - No Thanks, Please do not overclock my memory OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Large) Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement |
Quote Reply Posted: 18 Feb 2014 at 8:55pm |
Sweet!
Quote Reply Posted: 18 Feb 2014 at 9:07pm |
fstcvc
Quote Reply Posted: 18 Feb 2014 at 9:13pm |
Nice setup!!
HailStorm II
tallikat
Quote Reply Posted: 19 Feb 2014 at 7:35am |
thank you
Calibrator
Newbie Joined: 09 Mar 2014 Online Status: Offline Posts: 20 |
Quote Reply Posted: 15 Mar 2014 at 8:47pm |
It looks almost identical to my config that I plan on purchasing within the week! I am going with the regular 780 Ti over the superclocked for SLI compatibility in the future.
I am pondering between blue LED lighting or green. I know the case is green but it's not that pronounced. Which would look better? The green or the blue LED lighting?
Quote Reply Posted: 15 Mar 2014 at 11:21pm |
DS says, "With its military paint job, steel structure, and detonator inspired switches; no PC looks more battle-ready than the Marauder."
Military themed machine... green LED all the way.
tallikat
Quote Reply Posted: 16 Mar 2014 at 6:14am |
They're right, green all the way. The military theme is why I went with it. Also I'm just getting back into PCs, but from why I've read, the superclocked ti is SLI compatible. And you can definitely fit a second in the marauder case. I think anything more at this point in time might be a waste, for gaming anyways. Hopefully that's the case because I've already got my DS system. Regardless though, it's a beast of a system. Just played crysis 3 last night with everything maxed out. Awesome.
