GTX 760 performance/ Vanquish L3 help
Post Date: 2014-12-02
rexonenine View Drop Down
  Quote rexonenine Quote  Post ReplyReply bullet Topic: GTX 760 performance/ Vanquish L3 help
    Posted: 02 Dec 2014 at 5:16pm
Hi All,
I recently purchased the Vanquish level 3 and downloaded Far Cry 4. On my first few attempts to run the game it has been very laggy even when running it on medium settings. Is there a certain configuration process I should be going through prior to playing games on this PC? I am new to gaming pc's and just looking for any help or advice.
Thanks
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 02 Dec 2014 at 5:43pm
Put it on high and then dial back Anti-Aliasing to 2x or FXAA and see what happens
http://www.gamersnexus.net/game-bench/1701-far-cry-4-gpu-benchmark-amd-is-broken-again#!
Nav View Drop Down
Digital Storm Employee
  Quote Nav Quote  Post ReplyReply bullet Posted: 02 Dec 2014 at 6:54pm
What resolution are you running at ?
  Quote rexonenine Quote  Post ReplyReply bullet Posted: 02 Dec 2014 at 7:24pm
Im running it at 1080*1920
  Quote rexonenine Quote  Post ReplyReply bullet Posted: 02 Dec 2014 at 7:28pm
Okay I will try this and see how things go. I tried again earlier after installing nvidia software and using their optimized settings and got what seemed to be about 10 frames/sec which obviously looked atrocious.
Thanks for the help.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 03 Dec 2014 at 3:27am
I found this fix. Not sure it'll help, but worth a shot.
Navigate to the Far Cry 4 config file, which is typically located at My Documents\My Games\Far Cry 4\[account id name]\GamerProfile.xml and open it with WordPad or any other text editor.
Search for “DisableLoadingMip0="0"” and change the second 0 to a 1, so it should read “DisableLoadingMip0="1"”.
Progenitor View Drop Down
  Quote Progenitor Quote  Post ReplyReply bullet Posted: 03 Dec 2014 at 1:10pm
Originally posted by rexonenine
Hi All,
Thanks
Hey man, what you're experiencing is software related. I have a level 3 Apollo and experience this as well. It's also documented in a Youtube video by the use Totalbiscuit and around the 11:00 minute mark he comments on it.
Did you buy this through Steam or straight though Uplay? If you go to the Steam forums and search stuttering, there will be two major threads that come up. In one, an actual developer(not a moderator) actually responded to a few questions on the matter and she said they were aware of it and working on it.
That fix that was posted is also posted heavily on the Steam forums. That fix does muddy the textures some but does seem to help alleviate the issue for a good amount of people.
So no worries, your machine is fine!
  Quote rexonenine Quote  Post ReplyReply bullet Posted: 03 Dec 2014 at 5:12pm
Okay thank you! Thats really what I was worried about. I know Ubisoft has been having issues with their recent releases but I just wanted to make sure the machine was fine. Thanks again for your help!
