GPU / Monitor Question(s)Post Date: 2013-11-13 |
capto0924
Newbie Joined: 14 Jan 2012 Online Status: Offline Posts: 7 |
Topic: GPU / Monitor Question(s) Posted: 13 Nov 2013 at 1:19pm |
Good afternoon all,
I purchased a system a while ago from DS and I am wondering if I should go SLI or not. Here are my primary specs:
Question: Should I buy an identical vid card (Geforce 570 GTX HD) and go SLI so I can move up to a 24" or 27" 120hz or 1080p screen resolution? Could I effectively run a that 24" or 27" widescreen at it's native resolution and 1 of my old monitors on my existing setup without experiencing any lag/stutter/failure? Another Question: Would I be better off ditching the old card (still runs great) and upgrading to a series 7 with PCI-E 3.0? Would I still need to purchase another card if I wanted the same size monitor/refresh rate? Hey thanks for any input, been pondering this for a long-time. Figured I would ask the experts before I plunk down duckets :) |
Quote Reply Posted: 13 Nov 2013 at 2:08pm |
Hi capto0924.... You still have a strong system but the 570 might be feeling it's age if gaming on very high settings. I wouldn't invest in another older 570 but instead go for a gtx 770. It'll give you just a little less than sli 570 performance and get rid of any potential sli issues. Less heat, less power used and much better than the single gtx 570. The gtx 770 will play real nice on a 1080 monitor. The gtx 780 is better gaming but more money. Depends on the budget.
Good luck. You can run either card with a 1080 monitor and one of your older screens but it will take frame rate away from primary monitor. If the second monitor is just for web,etc then not a big penalty off gaming on one. Edited by bprat22 - 13 Nov 2013 at 2:13pm |
