Flexible gaming PCPost Date: 2014-08-04 |
Fuzzmasterxp
Newbie Joined: 04 Aug 2014 Online Status: Offline Posts: 1 |
Topic: Flexible gaming PC Posted: 04 Aug 2014 at 8:39am |
Hi there! Just trying to see if my current configuration will suit my needs. Budget:1800 Expectations: I really want dual monitors for my school work as it speeds up data input so much. I plan to use my 22" noc 1920x1080 monitor as the "document viewer" and the monitor included in my ticket as the primary video/game/work viewer. I am also looking to get into game broadcasting/youtubeing. Usage: Gaming, light video editing, grad school work Special Needs: My current monitor only has DVI and D-sub inputs and I am hoping I can still use it for a dual monitor set up. Saved Ticket #: 1023837 Specifications: Chassis Model: Special Deal Hot Seller - Pre-built Digital Storm VANQUISH II - Level 4 Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i5 4590 3.30 GHz (Quad Core) Motherboard: ASUS H81M-D/E Plus (Intel H81 Chipset) (MATX) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series Power Supply: 600W Corsair CX Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (120GB Samsung 840 EVO) Storage Set 2: 1x (1TB Seagate (7200 RPM) (64MB Cache) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 770 2GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: AIR: Stage 1: High Performance Cooler with Large Fan and Copper Pipes H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: - No Thanks, Please do not overclock my processor Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) |
Quote Reply Posted: 04 Aug 2014 at 9:13am |
Hi Fuzzmasterxp,,, Welcome to the forums.
The Vanquish level 4 is a lot of performance for the money. Nice. The gtx 770 has 2x DVI, a HDMI and a DisplayPort connector. Hooking the new monitor and the old should be no problem. Good Luck. |
