Fan upgrades
Post Date: 2014-12-26
Saajuk View Drop Down
  Quote Saajuk Quote  Post ReplyReply bullet Topic: Fan upgrades
    Posted: 26 Dec 2014 at 12:45pm
I was wondering what they mean by (up to 6 fans)? does that mean I have a choice of adding six fans or the package comes with 6 fans? under specs for Apollo.
Also does the Upgrade to corsair fans have led lights as well or not? didnt see an option so im guess no.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 11 Jan 2015 at 9:56am
Hi Saajuk,
I believe this is to upgrade the fans you have in your system. So if you have 8 fans in your system and you want to upgrade all of them there will be an additional charge for number 7 and 8.
I am not sure how it works if you only have 4 fans. I know they will upgrade the 4 fans to better fans but I don't know if they will add two more fans to your system. I suspect that they don't add fans but just upgrade the fans you already have. DS would have to clarify what they do when you have less than 6 fans in your system.
