Fan installation questionsPost Date: 2014-04-09 |
Topic: Fan installation questions Posted: 09 Apr 2014 at 7:11am |
I'm in possession of two 140mm blue LED fans (Very similar to these -- http://www.newegg.com/Product/Product.aspx?Item=N82E16835103077) and had a few questions should I decide to install them in the Corsair 230T (Vanquish II).
Thanks, still new to the upgrade / modification side of computers. Seeing all this room inside the Vanquish gives me an itch to poke around in there to see what I can learn. |
Quote Reply Posted: 09 Apr 2014 at 8:02am |
The mobo fan control I believe is within AI Suite, either already installed or on the mobo disc in your folder. Within AI Suite is Fan Xpert but it can only control the fans plugged into the mobo. Your mobo, H81M-E I think, only has a single chassis fan header that the front fans might be using. If you add the top fans you can drop the right side cover and pull out the extra 4 pin peripheral plugs from the harness and connect to them with 3-4 pin pass through adapter from Amazon, etc. You won't be able to control them without a separate fan controller or using a resistor pack that goes between the fan and its power source to drop voltage and rpm.
Hope this helps. |
Quote Reply Posted: 09 Apr 2014 at 11:39am |
It does, thank you.
