Eclipse lvl 4 cooling?Post Date: 2014-12-17 |
justJJ
Newbie Joined: 14 Dec 2010 Online Status: Offline Posts: 3 |
Topic: Eclipse lvl 4 cooling? Posted: 17 Dec 2014 at 2:04pm |
SO I bought my second DS gaming rig, last time (2011) I went expensive (but loved it), this time I am trying to stay on budget so I went with the Eclipse pre-built level 4- had just what I wanted, nothing additional. I over-did it last time and ended up never uphrading or adding additional cards etc...
So I AM planning on OC the CPU- nothing too crazy but I am concerned about the heat- it only has standard cooling- I assume it will be fine since it is an option, but thought I would see what everyone thinks. I was also concerned about the power supply some, since its only 400 watts and I will be running the i5 4690k and a GTX970, looks like it will barely be enough... Will overclocking to 4.5 cause issues with the factory heatsinks/fans? In case people need the config it is : Processor: Intel Core i5 4690K 3.50 GHz (Unlocked CPU) (Quad Core) Motherboard: GIGABYTE Z97N-WIFI (Intel Z97 Chipset) (Mini-ITX) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Power Supply: 400W Digital Storm Certified (Specialized Unit - Supports up to GTX 970) Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 8x / CD-Writer 8x) Storage Set 1: 1x SSD (120GB Samsung 840 EVO) Storage Set 2: 1x (1TB Seagate (7200 RPM) (64MB Cache) |
Quote Reply Posted: 17 Dec 2014 at 2:24pm |
Hi justJJ..... I asked that question of Alex , the overclocked cpu with factory cooler, and a 4.0 , 4.2 max, or so overclock is doable. For a higher oc, there are low profile coolers that Noctua and Silverstone sell.
Edited by bprat22 - 17 Dec 2014 at 2:27pm |
justJJ
Quote Reply Posted: 17 Dec 2014 at 2:40pm |
Perfect! Thanks very much.
Admin Group Digital Storm Supervisor Joined: 04 Jun 2012 Online Status: Online Posts: 16314 |
Quote Reply Posted: 17 Dec 2014 at 3:18pm |
bprat22 is right.
No need to worry about thermals. |
Quote Reply Posted: 17 Dec 2014 at 6:22pm |
I'm not sure how much the clearance is, but there could be the possibility to mount a slim all-in-one single 120mm fan radiator on the grill above the processor with a SY1212SL12H fan on it.
