DS Vanquish (which level?)
Post Date: 2015-05-05
Radicalp View Drop Down
  Quote Radicalp Quote  Post ReplyReply bullet Topic: DS Vanquish (which level?)
    Posted: 05 May 2015 at 9:20am
So, my current ------ x51 desktop computer seems to be on its last legs, and I've been searching the web for a suitable replacement. The great things that people have to say about Digital Storm's Vanquish model are overwhelming. So much praise!
I've been looking at the different levels of the Vanquish, and the level 3 seems to be the best bang for the buck while still fitting in the desired price point I want. My main interest in the level 3 is due to the GTX 970, which I understand is a significant upgrade from the 960. I was wondering if anyone would be willing to weigh in on the pros/cons of either upgrading to the level 4 or downgrading to the level 2.
Thanks for any advice you can provide!
Ideally below $1250
The main PC game I play is Final Fantasy 14: A Realm Reborn. I'm excited about the new expansion coming out, and want to play it using DirectX11 and max or near-max settings.
I also normally jump into new Korean MMOs that come overseas, currently Black Desert Online and Bless Online look gorgeous (if we ever get them).
I have been using ------ systems for the last 4-5 years (first a m14x laptop which I then replaced with my current x51 desktop) but I have been unimpressed with their build quality and longevity.
I would say I put my computers through their paces as far as usage goes. I normally game somewhere between 30-50 hours a week.
I don't think I have any. I like to keep up with gaming news via online videos, and I may be interested in streaming via Twitch or OBT.
Saved Ticket #: [Please Type Here]
Chassis Model: Special Deal Hot Seller - Pre-built Digital Storm VANQUISH 3 - Level 3
Processor: Intel Core i5 4590 3.30 GHz (Quad Core)
Motherboard: ASUS/GIGABYTE (Intel Z97 Chipset) (SLI Ready)
System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series
Power Supply: 600W Corsair CX
Storage Set 1: 1x SSD (120GB Samsung 850 EVO)
Storage Set 2: 1x (1TB Seagate (7200 RPM) (64MB Cache)
Storage Set 3: - No Thanks
RAID Config: - No Thanks
RAID Card: - No Thanks
Graphics Card(s): 1x NVIDIA GeForce GTX 970 4GB (Includes PhysX)
HPC Processor: - No Thanks
Extreme Cooling: AIR: Stage 1: High Performance Cooler with Large Fan and Copper Pipes
Airflow Control: - No Thanks
Boost Processor: - No Thanks, Please do not overclock my processor
Portable Gaming: - No Thanks
Branded Gear: - No Thanks
Priority Build: Ship Within 5 Business Days After Order Is Successfully Processed
Competitor name removed.
Edited by Snaike - 06 May 2015 at 3:46am
  Quote FrankW Quote  Post ReplyReply bullet Posted: 05 May 2015 at 1:32pm
Hi Radicalp,
If there is any way you can go for the Level 4 you will get a better system. The Level 4 system has a 4690k processor and you will get a better Over Clock. The SSD is double the size of the one on the level 3. You also get a 750w Power Supply that will provide a lot of overhead for expansion if you want to upgrade the system. Both levels have the 970 GPU.
It is up to you if these added features are important. The level three is a nice computer for the money. I would also pick the Original Chassis instead of the alternate unless you just like the looks of the alternate. If you buy the alternate case I would add an exhaust at the rear of the case.
Edited by FrankW - 05 May 2015 at 1:39pm
Pacesetter View Drop Down
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 05 May 2015 at 3:08pm
I'll echo Frank's comments.
The reason being, you mentioned some games and streaming. For the CPU intensive games the 4690K will be MUCH better suited and for streaming it is better at computes and multitasks mainly due to the overclocking. At base speeds the performance gain is little but with the overclocking you'll probably see about a 15% increase.
If upgrades are in the picture ( SLI etc) the level 4 is better suited because 3 upgrades are already done and much cheaper than doing it later. $139.00 for better CPU with overclocking, bigger SDD and P/S can't be beat.
I think for now the level 3 would be fine but you would be happier in the long run with the level 4.
  Quote Radicalp Quote  Post ReplyReply bullet Posted: 05 May 2015 at 3:41pm
Thanks for the help guys! Lots of good points you bring up. I think you've convinced me.
  Quote Radicalp Quote  Post ReplyReply bullet Posted: 05 May 2015 at 4:21pm
Verified Customer!
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 05 May 2015 at 4:23pm
Grats!   Happy gaming ahead.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 05 May 2015 at 4:36pm
Hi Radicalp,
Well you don't dilly-dally around.   Welcome to the Digital Storm family.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 05 May 2015 at 7:49pm
Storm Trooper
i5 3570k
Ordered: 11-27-12
Stage 1: 11-29-12
Stage 2: 12-2-12
Stage 3: 12-2-12
Stage 4: 12-4-12
Stage 5: 12-4-12
Stage 6: 12-10-12
Stage 7: 12-12-12
Snaike View Drop Down
Moderator Group
Moderator Group
  Quote Snaike Quote  Post ReplyReply bullet Posted: 06 May 2015 at 3:47am
That was quick!! Welcome to the family!
  Quote Radicalp Quote  Post ReplyReply bullet Posted: 17 May 2015 at 8:44pm
Awww, man. My Vanquish is supposed to come in on Tuesday. The Hype is real!
Steven View Drop Down
Moderator Group
Moderator Group
Digital Storm Employee
  Quote Steven Quote  Post ReplyReply bullet Posted: 18 May 2015 at 8:53am
If you feel up to it we would love to read a review of the system once you break it in!
  Quote Radicalp Quote  Post ReplyReply bullet Posted: 18 May 2015 at 9:29am
Definitely! I'm hoping to actually do an unboxing video (never done one before) and review.
  Quote Radicalp Quote  Post ReplyReply bullet Posted: 19 May 2015 at 8:46am
Look what came today! Excited
I took an hour from work this morning to drive over to the UPS center to pick it up.  Now I have to make it through the rest of the day until I can open it up... Cry
Edited by Radicalp - 19 May 2015 at 8:51am
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 19 May 2015 at 8:53am
Storm Trooper
i5 3570k
Ordered: 11-27-12
Stage 1: 11-29-12
Stage 2: 12-2-12
Stage 3: 12-2-12
Stage 4: 12-4-12
Stage 5: 12-4-12
Stage 6: 12-10-12
Stage 7: 12-12-12
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 19 May 2015 at 8:59am
Congrats.Awesome
I can remember the day mine arrived, although that is a much more colorful box than before.   Strong
Enjoy.
Moderator Group
Moderator Group
  Quote Snaike Quote  Post ReplyReply bullet Posted: 19 May 2015 at 10:13am
