Draining the loop
Post Date: 2012-06-11
tju76 View Drop Down
  Quote tju76 Quote  Post ReplyReply bullet Topic: Draining the loop
    Posted: 11 Jun 2012 at 8:56pm
Hey guys i was wondering if anyone had any good ideas on how to drain the loops in my pc, my system is the corsair 800d with full liquid cooling on the cpu and sli graphics card, also got the xspc dual bay, looking at it just seems like it will be a pain, i wish i would have thought to have DS install some drain valves in the bottom
surf71zx View Drop Down
  Quote surf71zx Quote  Post ReplyReply bullet Posted: 12 Jun 2012 at 10:02am
I had them install fill valves on top of case from Danger Dan, 3 of them for 3 reservoirs, and 3 drain valves.You can see pictures of it on Computer Build of the Month.To answer your question I would call DS and see  how they do it the easiest and best way.
  Quote Alex Quote  Post ReplyReply bullet Posted: 12 Jun 2012 at 10:59am
Are you trying to make changes to the cooling system which would cause the fluid to come out? Draining the system and adding fluid again would take more time than doing the following:
1. Place a clear plastic around your components and the barb you want to disconnect.
2. Place some paper towels around the barbs you are going to open.
3. After you disconnect the barbs, place a cork or something similar and plug the holes.
4. Conduct your changes.
5. Place everything back in
6. Add additional fluid (we use Feser One clear usually).
  Quote tju76 Quote  Post ReplyReply bullet Posted: 12 Jun 2012 at 11:00am
Yeah i saw yours and was like damn why didn't I think of that, I will call ds and see what they recommend if I ever send it back I will have them add drain ports
  Quote tju76 Quote  Post ReplyReply bullet Posted: 12 Jun 2012 at 11:03am
   this would be for when I need to drain and clean it out, I will post pics if that will help.
Err0xx View Drop Down
  Quote Err0xx Quote  Post ReplyReply bullet Posted: 12 Jun 2012 at 2:15pm
Speaking of this, which coolant is used in the CRYO-Tec cooling systems? Does the Feser One have a low enough freeze point to be used with this? Just wondering for when I eventually have to change my coolant on the Aventum.
Edited by Err0xx - 12 Jun 2012 at 2:37pm
  Quote tju76 Quote  Post ReplyReply bullet Posted: 12 Jun 2012 at 6:20pm
just a reminder i need advice on how to drain the entire system thanks
