? Does this work
Post Date: 2008-09-17
tirnaog View Drop Down
  Quote tirnaog Quote  Post ReplyReply bullet Topic: ? Does this work
    Posted: 17 Sep 2008 at 11:35am
Hello all,
I have a 4 core system and wondered if this was true or not.
Thanks
Deasun
My DS PC:
CPU: Intel i7 2700K OCed 4.4ghz
MB: {not sure :( }
Memory: 8 gigs
Video: 570 GTX 1gb nVideo
Sound: Built in
OS: Win7 64 Ultimate
Kelly View Drop Down
  Quote Kelly Quote  Post ReplyReply bullet Posted: 17 Sep 2008 at 2:46pm
I'll be trying it when I get home :)
  Quote Kelly Quote  Post ReplyReply bullet Posted: 17 Sep 2008 at 2:55pm
jsut tested it on a system here at work. 27sec to boot normally and 12sec after the little tweak.
Axel Daemon View Drop Down
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 17 Sep 2008 at 3:24pm
Wow nice improvement.
"People believe in people who believe in others."
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Sep 2008 at 4:10pm
this won't make no difference how ever if people have load of stuff to start with vista
  Quote tirnaog Quote  Post ReplyReply bullet Posted: 22 Sep 2008 at 7:36am
Morning all,
Tried it on 2 of my PCs, DS desktop and my HP laptop. Seemed to work!
Nice little boost that.
My DS PC:
MB: {not sure :( }
Memory: 8 gigs
Sound: Built in
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Sep 2008 at 4:36pm
had 8 of my forum members try it (they keep their start clean) they noticed no difference, however now you have your vista not booting in normal mode
  Quote tirnaog Quote  Post ReplyReply bullet Posted: 23 Sep 2008 at 7:29am
Not sure what you mean by "Normal mode", I have seen no changes orther then a faster boot up.
My DS PC:
MB: {not sure :( }
Memory: 8 gigs
Sound: Built in
gamerk2 View Drop Down
  Quote gamerk2 Quote  Post ReplyReply bullet Posted: 23 Sep 2008 at 8:49am
The only thing this does is make the extra cores kick in faster,  If you have 10+ things booting at startup, of course you will see a diffrence, as the computer will be using all the cores instead of one while booting.  If you have only a few things load on startup, there will be no diffrence.
Randy6500 View Drop Down
  Quote Randy6500 Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 12:54pm
I tried it on Vista 32 bit and it made a significant difference.  Neat trick!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 3:30pm
randy you got too many things starting with your vista, your problem is that your startup list needs cleaning.
@tirnaog, msconfig and see if you are set to boot normal or not? you will see its not. If you should have some problems with your OS, not booting normal can cause further problems, and you would never know, that it was that causing it.
