Deciding time. Bolt questionsPost Date: 2013-05-04 |
tbonefromwisconsin
Newbie Joined: 13 Apr 2013 Online Status: Offline Posts: 21 |
Topic: Deciding time. Bolt questions Posted: 04 May 2013 at 4:55pm |
1500 Expectations: Needs to run fps like bf3 Usage: Gaming/ schoolwork Special Needs: Preferably small Saved Ticket #: [Please Type Here] Specifications: [Please Type Here] So I talked to my mom abut what she thought I should get and she said . 1. Try not to go over 1500 2. Size is now a factor. So I told her about the bolt and she liked it So now I come to the forms for advice. I was wondering about the bolt lvl 3s cooling and if the bolt 3s cooling isn't much better, I will save some money and go with the lvl 2. I was also wondering if the extra ssd in the bolt 3 is worth spending the extra money on. Scence the bolt is probley the most customizable of the limited coustomizations I was woundering what config might best fit me. |
Nomad1970
Senior Member Joined: 23 Feb 2013 Online Status: Offline Posts: 716 |
Quote Reply Posted: 04 May 2013 at 5:10pm |
You might look at a level 2 Bolt with the video card changed out to a 670 2GB. That would cost $1470.00 plus shipping.
My Precious 2
I7-9700 oc 4.7GHz 32GB DDR4 3000MHz Corsair Vengeance RGB Pro SSD M.2 (512GB Samsung 970 PRO) SSD M.2 1TB Samsung 970 EVO 240GB Samsung 860 Pro SSD 1TB W.D. HD EVGA GTX 1080Ti |
