Deciding between two modelsPost Date: 2012-11-28 |
aidan23
Newbie Joined: 28 Nov 2012 Online Status: Offline Posts: 3 |
Topic: Deciding between two models Posted: 28 Nov 2012 at 8:41pm |
Budget: 1200 (roughly)
I am firstly very glad I found you this you guys come with some high praise from the magazine I read (PCgamer) and the time has come for me to replace my old machine, which I have not-so-lovingly named "The Jet Engine". After doing some research I have pared my options to either the Maurader level 4 or the Bolt level 2. I live in a rather small space and was wondering if the Bolt will be just as effective as I have read the maurader will be. It would be nice to actually set the computer on the desk behind my monitors to save space. I will be using this machine for mostly games such as WoW and GW2, but not limited to those (skyrim, new bioshock, etc). I just wanted your guys opinions on the matter. Thanks Future Customer, Aidan23 |
Quote Reply Posted: 28 Nov 2012 at 8:55pm |
I think you would be better off with the Maurader it has the Cooler Master Hyper 212 which has great reviews and the case being big will keep your computer from overheating. Just my opinion on the whole deal.
Edited by ArkansasWoman777 - 28 Nov 2012 at 8:55pm |
Quote Reply Posted: 28 Nov 2012 at 8:58pm |
Also the Maurader would be less noiser. If you look at the Bolt and Maurader you can see the difference in cooling and the noise level.
aidan23
Quote Reply Posted: 28 Nov 2012 at 10:52pm |
Does the bolt have overheating problems? also I am not sure that noise the way you are thinking and noise of the caliber of my current comp are the same thing. The fans on the current comp I think are loud even through my g35 headphones so either of these would be a step up in that department.
Quote Reply Posted: 29 Nov 2012 at 3:05am |
Now i don't know if it would have heating problems. I mean its smaller than the Maurader but i think Alex or somebody would have to tell you for sure.
Edited by ArkansasWoman777 - 29 Nov 2012 at 3:06am |
Quote Reply Posted: 29 Nov 2012 at 4:24am |
Its tough to compare the Bolt to other mainstream systems. Its unique to DS and until other users give feedback or websites test it we have to trust that DS, and I do, tested it and are comfortable with the heat/noise signatures.
The Marauder 4 does have a bit better video card and more room for growth and easier to work on. The Bolt is nice for space challenged setups and will perform within 10% of the M4 in gaming. Hope this helps. |
aidan23
Quote Reply Posted: 29 Nov 2012 at 11:37am |
okay so forgetting the bolt because I am not so sure that I really want a mini pc right now seeing as how it seems we would need to buy it on faith and I am to impatient to wait on reviews. So comparing desktops then I looked at the Ode 1 and it only has two differing things
1) A slightly better graphics card 2) The overclocking What I would like to know is do those things really matter in the long run? Every review I have seen raves about the ode. Is it really that superior? or should I save the 200 and go with the M4. |
Quote Reply Posted: 29 Nov 2012 at 11:53am |
Hi aidan23.... For the $200 you'd be getting a better case with more features like 4x usb 2.0 ports and 1x usb3.0 port on top front and better cooling with its top 200mm fan kicking heat out the top. Also the 600T case has internal lighting and a front and top LED fan, white. Not sure that's important to you. Also a fan control that varies the speed some but not alot. Also, the gtx 670 is a better video card.
Not sure what you play or the monitor you use but here's link that compares the two cards with different games, resolutions. http://www.anandtech.com/bench/Product/647?vs=598 Might help you decide. Also, the overclocking will give you a few more frames per second with some games and little with others. Good luck and whatever you go for remember the free t-shirt. |
Quote Reply Posted: 29 Nov 2012 at 1:18pm |
The Bolt does not have overheating problems, if it did, we never would be offering it on our website.
In addition, we made improvements to the power supply design, all Bolt orders will receive a unit that is quiet. |
