Couple of newbie questions..
Post Date: 2014-10-26
stormricker View Drop Down
  Quote stormricker Quote  Post ReplyReply bullet Topic: Couple of newbie questions..
    Posted: 26 Oct 2014 at 10:42am
Hi all - the other member recently - it has been almost 6 years since I built my last rig. This time around - I am going for a custom build and DS came up along with -----.
1. Do the computers come with both side panels? The pictures seem to show the side off.
2. Can we change cases....say to the Velox when ordering  a Hailstorm 2?
3. Is the liquid cooling reliable and maintenance free?
Any other thoughts are most welcome!Big%20Smile
EDIT: Competitor name removed - Alex
Edited by Alex - 26 Oct 2014 at 12:02pm
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 26 Oct 2014 at 10:56am
Yes the computers come with both side panels. Yes you can change the chassis (cases) in the configuration not sure about changing in the middle of DS building it. The radiators are maintenance free and are sealed.
Edited by ArkansasWoman777 - 26 Oct 2014 at 10:58am
Storm Trooper
i5 3570k
Ordered: 11-27-12
Stage 1: 11-29-12
Stage 2: 12-2-12
Stage 3: 12-2-12
Stage 4: 12-4-12
Stage 5: 12-4-12
Stage 6: 12-10-12
Stage 7: 12-12-12
  Quote Alex Quote  Post ReplyReply bullet Posted: 26 Oct 2014 at 12:06pm
Hi stormricker,
Welcome to our forums and thank you for considering Digital Storm, we would love to have you as a customer.
Looks like Arkansas hit the nail on the head, the units do come with both side panels.
If you want to change the case, you can easily do so by selecting the "Change" button on the "Chassis" section on the configurator.
For zero maintenance liquid cooling, you should select either the Corsair liquid coolers our the Digital Storm Vortex liquid coolers.
  Quote stormricker Quote  Post ReplyReply bullet Posted: 26 Oct 2014 at 4:36pm
Thanks for input. Here is my first workup:
1071344
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 26 Oct 2014 at 5:06pm
Looks fine to me although given the design of the case i would suggest changing to the Digital Storm Thermal Management Control Board & Software and the Digital Storm RGB LED Lighting System. I don't think the temp display you chose would fit given the design and given the fact there is only one optical drive slot.
That way you can configure the led lights to monitor the temps with the software
Edited by ArkansasWoman777 - 26 Oct 2014 at 5:07pm
Storm Trooper
i5 3570k
Ordered: 11-27-12
Stage 1: 11-29-12
Stage 2: 12-2-12
Stage 3: 12-2-12
Stage 4: 12-4-12
Stage 5: 12-4-12
Stage 6: 12-10-12
Stage 7: 12-12-12
  Quote stormricker Quote  Post ReplyReply bullet Posted: 26 Oct 2014 at 5:09pm
Gotcha....
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 26 Oct 2014 at 5:16pm
Also the extreme cooling you chose i believe requires maintenance over time, so if you want maintenance free liquid cooling its best to choose the radiator coolers like Alex and i mentioned. They are pre-filled and sealed and require no maintenance unless the pump fails but i think its probably rare.
Course there is always the option of air cooling the system
Storm Trooper
i5 3570k
Ordered: 11-27-12
Stage 1: 11-29-12
Stage 2: 12-2-12
Stage 3: 12-2-12
Stage 4: 12-4-12
Stage 5: 12-4-12
Stage 6: 12-10-12
Stage 7: 12-12-12
  Quote stormricker Quote  Post ReplyReply bullet Posted: 27 Oct 2014 at 4:33am
OK - is this better?
Snaike View Drop Down
Moderator Group
Moderator Group
  Quote Snaike Quote  Post ReplyReply bullet Posted: 27 Oct 2014 at 6:23am
which this?
  Quote stormricker Quote  Post ReplyReply bullet Posted: 27 Oct 2014 at 4:15pm
Sorry - I was in a hurry.....
1071788
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 27 Oct 2014 at 4:23pm
Looks good except for the airflow control thingy as i mentioned in my post up above. I changed it for you course you don't have to save this link if you don't want to. DS will always contact you if something doesn't work
https://www.digitalstormonline.com/configurator.asp?id=1072122
Storm Trooper
i5 3570k
Ordered: 11-27-12
Stage 1: 11-29-12
Stage 2: 12-2-12
Stage 3: 12-2-12
Stage 4: 12-4-12
Stage 5: 12-4-12
Stage 6: 12-10-12
Stage 7: 12-12-12
  Quote stormricker Quote  Post ReplyReply bullet Posted: 27 Oct 2014 at 5:37pm
Got it.....
