Hi RICK2197... Here's my thoughts and a config to check out, kind of a combo of what was said and my spin.
Config # 713948 Cost $ 3542
Office: Microsoft Office 2010 Home and Student (Full Retail Box Packaging)
This gives you the same gaming performance for $1800 less.
The HafX case is tops for air cooled systems and doesn't need the noisy Zalman fan upgrade and has built in hot-swap bays. Also doesn't need the noise suppression package.
The Z77 mobo is all gaming needs. If you plan on going to a third graphics card, then the X79 would be needed, but that didn't seem to be an issue.
The 1050HX is great for sli.
For tops in dependability I put in the Noctua D14 cooler. The stage 4 cooler you listed is also very good, just has more plumbing to worry about.
Just another way to go. Good Luck.
Edited by bprat22 - 31 Jul 2012 at 6:40am
