Build 7601Post Date: 2013-08-16 |
Raviont
Newbie Joined: 09 Jul 2013 Online Status: Offline Posts: 13 |
Topic: Build 7601 Posted: 16 Aug 2013 at 8:19pm |
Hello forum guru's and DS team =P
Yesterday I came into a predicament, I got a computer from here not more then a month ago so still new... but yesterday my wallpaper went black on down at bottom right in white letters says "Windows 7 Build 7601 This version of Windows is not genuine" 1.Why is this showing up and 2. shouldn't of the copy DS install be Genuine??? help please ^^ |
fstcvc
Quote Reply Posted: 16 Aug 2013 at 10:29pm |
I know when building computers, they are using a single copy to install and when you register the machine with MS, it normally asks for the serial number (not sure if DS does this for you). I'm pretty sure DS is installing a valid version for you and something didn't go right with the activation with MS. Here's a link to MS's page on how to validate/repair your system.
You should also contact DS if you're unable to resolve this easily ([email protected] or [email protected]). Hope this helps! |
HailStorm II
Quote Reply Posted: 17 Aug 2013 at 3:31am |
Just to add, DS does activate the software but sounds like a glitch. Your MS product key, needed for activation, is on a sticker on the outside of the rig. Mine is on right side panel. Just follow the activation steps.
Any issues, give DS a call. |
Raviont
Quote Reply Posted: 17 Aug 2013 at 8:30am |
Thx for the replies i'll trying getting it done once I get home from work
Quote Reply Posted: 17 Aug 2013 at 8:16pm |
Correct. That warning is simply because you need to re-activate your operating system or else Microsoft will not consider it "genuine."
Sometimes Windows will un-activate itself out of a glitch by some software/utility making wrong changes to the Windows registry. Feel free to call us for help, but what you might need to do is just re-activate it. You may need to call the toll-free number the activation wizard provides you to verbally let them know that you own the computer and that it's only installed on your system. |
