Bolt II Hardline coolingPost Date: 2014-09-23 |
redchaostry
Newbie Joined: 19 Aug 2011 Online Status: Offline Posts: 7 |
Topic: Bolt II Hardline cooling Posted: 23 Sep 2014 at 5:12am |
Getting ready to order a Bolt II (shortly after the Asus Maximus VII Impact is available) and had a quick question about the new cooling option that is available, the Hardline: Digital Storm Acrylic Tubing Custom Cooling System.
Is there any performance improvements/differences between it and the standard liquid CPU cooler, or is it just mainly just a cosmetic option? And no chance of CPU/GPU cooling with it? Thank you for your time. |
Quote Reply Posted: 23 Sep 2014 at 6:30am |
The Hardline cooling option is more for looks than performance, IMHO. That and the 240mm rad sealed cooler will both get the job done about the same.
Just cpu cooling. I think space is the issue for a cooling block and fittings, as it being a SFF case, plus there is no separate reservoir , but a fill port for the loop. It does have a seperate pump instead of the smaller self contained pump of the sealed units, which might add to some performance and reliability, but DS would be a better judge of that. The Hardline looks awesome in my book, but not needed. Hope this helps a bit and good luck. Edited by bprat22 - 23 Sep 2014 at 6:33am |
graav
Newbie Joined: 28 Sep 2014 Online Status: Offline Posts: 2 |
Quote Reply Posted: 28 Sep 2014 at 8:54pm |
I was also wondering about this. Would you still have to replace the liquid inside this cooling system in time / How long would it last?
Quote Reply Posted: 29 Sep 2014 at 3:34am |
Being a water cooled system, minus the reservoir, it would need the same maintenance. Some change their fluid every 6 months but most wait a year or more.
Quote Reply Posted: 29 Sep 2014 at 5:23am |
Custom water cooling requires regular maintenance. Like bprat22 said, it should be done between 6 months to once year. When doing this, you should flush the system, usually with distilled water, than change the cooling fluid. I am sure their a youtube videos out there on this. Honestly, from what I have read, distilled water is the best fluid to use in a liquid cooling system. Most like to add a little biocide and some use an anti corrosion agent as well. It is best to keep the computer off during this process, you can get a jumper that connects to the 24-pin motherboard power supply cable to start it without having the motherboard running.
