Bolt and HEATPost Date: 2014-06-29 |
Cygnus7
Newbie Joined: 29 Jun 2014 Online Status: Offline Posts: 2 |
Topic: Bolt and HEAT Posted: 29 Jun 2014 at 10:35am |
I recently purchased a Bolt and its not overclocked. I am running the Intel Core i7 4770K processor with the ROG systemboard.
I decided to run Prime95 on it for the first time and after about 10 minutes, all 4 of my proc's were running at either 95c or 101c and it looked like it was still climging so i ended the test. Would like some advice. Wildstar pushes the temps to about 63c I just wanted to see if that is to be expected or should i open a ticket with help/support. Here are my specs. Chassis Model: Special Deal Hot Seller - Pre-built Digital Storm Bolt Exterior Finish: Pearl White Matte Finish with Black Vents and Black Stand Horizontal Stand: Horizontal Stand for Bolt <b></b> Processor: Intel Core i7 4770K 3.50 GHz (Unlocked CPU) (Quad Core) Motherboard: ASUS MAXIMUS VI IMPACT (Intel Z87 Chipset) (Mini-ITX) (SupremeFX Impact, Sonic Radar) <b></b> System Memory: 16GB DDR3 2133MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) <b></b> Power Supply: 500W Gold Plus Series Digital Storm Certified BOLT Edition (Enhanced Quiet Operation) Expansion Bay: - No Thanks Optical Drive: Blu-Ray Player (Blu-Ray 6x) & DVD/CD Writer <b></b> Storage Set 1: 1x (128GB Solid State (By: Samsung) (Model: 840 Pro Series) <b></b> Storage Set 2: - No Thanks <b></b> Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 780 Ti 3GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: High Performance Cooler with Four Heatpipes H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Standard Factory Chassis Fans Edited by Cygnus7 - 29 Jun 2014 at 3:48pm |
Quote Reply Posted: 29 Jun 2014 at 10:46am |
Prime95 is at the top of cpu stress testing, but those temps are still too high in my book.
What cooler do you have? Make sure the fan is working, no dust buildup in the small spaces behind the fan where the cooling fins are. Make sure the fans are on performance in the Bios. Sometimes they're tweaked down for lower noise. You can also try IntelBurnTest or OCCT to stress and compare temps. OCCT has its own monitoring or use HWMonitor for a second opinion for the others. Edited by bprat22 - 29 Jun 2014 at 10:53am |
Cygnus7
Quote Reply Posted: 29 Jun 2014 at 3:48pm |
Thank you for the suggestion. QFan is enabled on the proc and the chassis fans. The preset was set to standard, i changed it to turbo and it performed much better, now it took about 10 minutes using Prime95 to get the temp to 100c.
I want to try turning off qfan and see if that makes any difference, but right now my daughter is watching a movie on the apple TV so i can't reboot LOL thanks again for your reply. I updated my post with the specs. I am also using HWMonitor to get my temps. |
