Bolt 3 pci slot?Post Date: 2015-04-15 |
cmihelich
Newbie Joined: 15 Apr 2015 Online Status: Offline Posts: 10 |
Topic: Bolt 3 pci slot? Posted: 15 Apr 2015 at 11:55am |
Hi I'be been looking at the bolt 3 line and was wondering if it had a pci slot?
Quote Reply Posted: 15 Apr 2015 at 12:41pm |
The Bolt's mini motherboards have a single Pciex16 slot for the graphics card. The graphics card connects to the mobo's Pcie slot by way of a flexible ribbon cable, riser cable, so it can mount the way it does.
Some motherboards also have a mini Pcie slot for the WiFi module. Hope this helps. Edited by bprat22 - 15 Apr 2015 at 12:52pm |
cmihelich
Quote Reply Posted: 15 Apr 2015 at 2:26pm |
Well I was thinking about getting the avermedia capture card, so would it not work (sorry about dumb question I don't know much about computers
Quote Reply Posted: 15 Apr 2015 at 2:56pm |
The mini motherboards in Bolt don't have any extra pci slots for added cards. For that, you'd need to get a different case that excepts a larger mobo.
No dumb questions here. Glad to help. Edited by bprat22 - 15 Apr 2015 at 2:57pm |
cmihelich
Quote Reply Posted: 15 Apr 2015 at 4:11pm |
ok i will probably still get this computer though because of how small it is (perfect for my small area where it is gonna go) but i was wondering if this is a good build for it
Chassis Chassis Model: Pre-built Digital Storm Bolt 3 Exterior Finish: Black Brushed Aluminum Hairline Finish Core Components Processor: Intel Core i5 4690K 3.50 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: ASUS H97I-PLUS (Intel H97 Chipset) (Mini-ITX) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 450W SilverStone ST45SF (Bronze Rated) (Supports up to GTX 980) Storage / Connectivity Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 8x / CD-Writer 8x) Storage Set 1: 1x SSD (120GB Samsung 850 EVO) Storage Set 2: 1x Storage (1TB Seagate) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics / Multimedia Graphics Card(s): 1x NVIDIA GeForce GTX 960 2GB (Includes PhysX) Sound Card: Integrated Motherboard Audio Digital Storm Engineering Extreme Cooling: Custom Digital Storm 240mm Liquid Cooling System H20 Tube Color: Blue Tubing with High-Performance Fluid (UV Lighting Reactive) Chassis Fans: High Static Pressure - Corsair Air Series SP120 Fans (2x 120mm) Digital Storm TwisterBoost Technology Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): Yes, Overclock the video card(s) as much as possible with complete stability I wont do much "hardcore gaming", but is still will probably play alot |
Quote Reply Posted: 16 Apr 2015 at 3:51am |
That's a nice setup. I would change the Seagate HDD to the Western Digital Black for $19. A better drive with longer warranty.
The gtx 960 will give very good gaming on a 1920x1080 monitor or less. If budget is tight and you wanted to game at higher settings for an extra year or two, I would drop the water cooling and put the money into the gtx 970. But, the water cooling is a nice feature and if you're not hardcore then this is certainly a nice setup. Good luck and stay in touch. Edited by bprat22 - 16 Apr 2015 at 3:52am |
cmihelich
Quote Reply Posted: 16 Apr 2015 at 7:08am |
Do you think getting them to overclock my graphics cards would work well, or should i get the 970?
Quote Reply Posted: 16 Apr 2015 at 7:25am |
The added overclock they'll put on the 960 card won't give you very much. Maybe a couple of frames per second. I'd save the money. The gtx 970 will be a big boost over the 960, about 40% better in some games.
Edited by bprat22 - 16 Apr 2015 at 7:29am |
Quote Reply Posted: 16 Apr 2015 at 8:19am |
Looks like a solid setup. While overclocking the 960 will give you a small boost in performance, saving up a little more for the GTX 970 will make a BIG difference in performance. Not to mention, the 970 also has about double the VRAM.
