Best experiencePost Date: 2010-03-28 |
tom_p12
Newbie Joined: 28 Mar 2010 Online Status: Offline Posts: 3 |
Topic: Best experience Posted: 28 Mar 2010 at 1:25pm |
Had my Digital Storm system for six months now and could not be more pleased. I love it. Due to budgetary constraints (no job at the moment) mine is basic rig.
Digital Storm Desktop 167935
I had shopped for months and the reviews on this forum and Digital Storm's very informative website convinced me. From the time I placed my order I was treated like their best customer. The computer arrived in excellent condition and has performed flawlessly from the minute I turned it on. It's used for general computing as much as gaming and the speed is amazing.
System Configuration: Chassis Model: Special Deal Hot Seller - HAF 922 Processor: Intel Core i5 750 2.66GHz (Quad Core) Motherboard: EVGA P55 LE Edition (Intel P55 Chipset) System Memory: 4GB DDR3 1333MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested) Power Supply: 700W Digital Storm Certified (Dual SLI Compatible) (Silent Edition Recommended) Hard Drive Set 1: Operating System: 1x (500GB Western Digital (16MB Cache) (7200 RPM) (SATA) Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card(s): 1x NVIDIA GeForce GTS 250 1GB (Includes PhysX Technology) Sound Card: Integrated Motherboard Audio Extreme Cooling: Standard Factory Heat-sink and Fan Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Blue) CPU Boost: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade) Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) --------[ EVEREST Ultimate Edition ]------------------------------------------------------------------------------------
Operating System Microsoft Windows 7 Home Premium 6.1.7600 (Win7 RTM)
Date 2010-03-28 Time 11:50 --------[ Overclock ]--------------------------------------------------------------------------------------------------- CPU Properties:
CPU Type QuadCore Intel Core i5 750 CPU Alias Lynnfield CPU Stepping B1 Engineering Sample No CPUID CPU Name Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz CPUID Revision 000106E5h CPU Speed:
CPU Clock 3620.8 MHz (original: 2667 MHz, overclock: 36%) CPU Multiplier 20x CPU FSB 181.0 MHz (original: 133 MHz, overclock: 36%) QPI Clock 3258.8 MHz Memory Bus 724.2 MHz DRAM:FSB Ratio 4:1 CPU Cache:
L1 Code Cache 32 KB per core L1 Data Cache 32 KB per core L2 Cache 256 KB per core (On-Die, ECC, Full-Speed) L3 Cache 8 MB (On-Die, ECC, Full-Speed) Motherboard Properties:
Motherboard ID 65-0100-000001-00101111-102309-LfdHvdImc$1E653A39_BIOS DATE: 10/23/09 16:17:15 VER: 08.00.16 Motherboard Name Unknown Chipset Properties:
Motherboard Chipset Intel Ibex Peak P55, Intel Lynnfield Memory Timings 11-11-11-29 (CL-RCD-RP-RAS) Command Rate (CR) 1T DIMM1: Mushkin 991585 (996585) 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (6-6-6-16 @ 444 MHz) DIMM3: Mushkin 991585 (996585) 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (6-6-6-16 @ 444 MHz) BIOS Properties:
System BIOS Date 10/23/09 Video BIOS Date 02/19/09 DMI BIOS Version 080016 Graphics Processor Properties:
Video Adapter Zotac GeForce GTS 250 GPU Code Name G92GTS (PCI Express 2.0 x16 10DE / 0615, Rev A2) GPU Clock (Geometric Domain) 738 MHz (original: 740 MHz) GPU Clock (Shader Domain) 1836 MHz (original: 1836 MHz) Memory Clock 1101 MHz (original: 1100 MHz) I started my career as a computer tech and have had many in my home since 1980. The build quality of this one is the best I have seen.
I hope to add components as my budget allows. So far the only upgrade is a Cooler Master Hyper 212 Plus with 2 120mm fans. It was easy to install in this chassis and works great.
I highly reccomend Digital Storm. This is an excellent computer and they are a pleasure to deal with. |
Quote Reply Posted: 28 Mar 2010 at 4:32pm |
Hi Tom, thanks for sharing your system with us. You really get a clean install with DS and the HAF cast. I wonder how you got over clocked but no fan upgrade. I guess the i5 runs cooler than the i7.
Frank |
cswiacki
Newbie Joined: 16 Mar 2010 Online Status: Offline Posts: 40 |
Quote Reply Posted: 28 Mar 2010 at 9:16pm |
Looks good, DS really puts in a good effort for their customers.
OutlawedPanther
Newbie Joined: 04 Mar 2010 Online Status: Offline Posts: 38 |
Quote Reply Posted: 28 Mar 2010 at 11:32pm |
Ooo very nice!
tom_p12
Quote Reply Posted: 29 Mar 2010 at 10:42am |
The case came with a 200mm side fan. I temporarily removed it at Christmastime to show off the internals to guests. It's back on.
ShadowStar
Groupie Joined: 18 Nov 2008 Online Status: Offline Posts: 140 |
Quote Reply Posted: 29 Mar 2010 at 1:36pm |
That is a great looking machine!
Walking the line between realities
Bullseye
Senior Member Joined: 11 Jan 2010 Online Status: Offline Posts: 880 |
Quote Reply Posted: 29 Mar 2010 at 2:47pm |
Awesome Dude!!!
rholyrag
Senior Member Joined: 17 Oct 2009 Online Status: Offline Posts: 841 |
Quote Reply Posted: 01 Apr 2010 at 12:48pm |
Nice looking rig! Thanks for the pics!
sirsiddius
Groupie Joined: 18 Aug 2009 Online Status: Offline Posts: 441 |
Quote Reply Posted: 01 Apr 2010 at 2:14pm |
Is that a a stock intel cooler, my word I haven't seen on of those in ages.
DST4ME
DS ELITE Joined: 14 Apr 2008 Online Status: Offline Posts: 36760 |
Quote Reply Posted: 01 Apr 2010 at 3:58pm |
ya stock cooler, 3.6Ghz oc very nice
great looking build too, congrats |
tom_p12
Quote Reply Posted: 02 Apr 2010 at 12:55pm |
Shortly after receiving my new machine I installed a Cooler Master Hyper 212 Plus with an additional Cooler Master 120mm blue LED fan. It looks good and cools great. However the original Intel cooler worked fine, I imagine due to all the fans and the excellent air flow through the case. |
Sodius
Senior Member Joined: 18 Jan 2009 Online Status: Offline Posts: 613 |
Quote Reply Posted: 03 Apr 2010 at 12:26pm |
Awesome, looks clean and neat inside. Enjoy that beats.
