Aventum IIPost Date: 2014-10-19 |
Guests
Guest |
Topic: Aventum II Posted: 19 Oct 2014 at 12:38pm |
How easy is the Aventum II accessible to the motherboard, was just wondering if I would have to taking everything out to get to the motherboard.
Quote Reply Posted: 19 Oct 2014 at 2:40pm |
Depends what you're wanting to do. You can get to the motherboard by simply removing the side panel. Now if you want to remove the motherboard... that's a different story.
When using hardline or even metal tubing, you no longer have the quick disconnects. So we're talking about draining your loops, then removing the gpu's. Then removing the motherboard. Once all done, reinstalling everything and refilling our loops. Liquid cooling can be a pain. |
Quote Reply Posted: 20 Oct 2014 at 6:05am |
Which is why I wouldn't ever consider hard line liquid cooling, it makes any sort of maintenance much harder. But, I am a function over form kinda guy. ;-) |
Quote Reply Posted: 20 Oct 2014 at 8:44am |
I love my hard line cooling.
If done right, you still have some soft tubing, but it's usually in the back of the case where you do your cable routing. That allows you to be able to drain your system with ease. |
