AMD 45nm Phenoms might come earliar than expected.Post Date: 2008-11-04 |
skyR
Topic: AMD 45nm Phenoms might come earliar than expected. Posted: 04 Nov 2008 at 11:54am |
Digitimes |
PatrickB
DS Veteran Joined: 19 Oct 2008 Online Status: Offline Posts: 544 |
Quote Reply Posted: 04 Nov 2008 at 11:11pm |
Wouldn't going from Quad Cores to triple-core's be a step back?
Or is there some increased efficiency design? |
Q9550 @ 3.4Ghz for now
Xigmatek Thor's Hammer MSI P45 Neo2-fr 6gig 1066 Corsair Dominator XFX Radeon HD 4890 PC Power&Cooling 750W Seagate Barracuda 500Gb Antec 900 Vista 64bit |
skyR
Quote Reply Posted: 04 Nov 2008 at 11:15pm |
AMD has had triple cores for a while now... where have you been -.-?
PatrickB
Quote Reply Posted: 04 Nov 2008 at 11:18pm |
Under a rock obviously
widdlecat
DS Veteran Joined: 11 Mar 2008 Online Status: Offline Posts: 840 |
Quote Reply Posted: 04 Nov 2008 at 11:22pm |
The Phenom 20550 is what I been hoping to see results on. Early overclocks seem to suggest that with a mobo setup of 790FX chipset and 750sb, it can run pretty fast. Was 3.6GHz with a tec and one mention of a 4.0GHz on liquid cooling. Now to see what real people will be getting...
Patrick, the triple-cores are basically phenom quads where one of the processors doesn't meet spec and is therefore disabled. The three other cores run fine and are sold at a price reduction. In most cases that I've seen reports of multicores, the 3cores perform right in between dual core and quad core as would be expected. I like their concept of a triple core as it reduces waste and makes for less costly quad cores that DO meet spec. Also, wasted silicon is just a shame. After all, the materials used in manufacturing wafers are very pure and quite costly. In the end, any waste is paid for by the consumer. As a poor consumer, in the end I may upgrade from my dual core to a triple core... instead of going on to a quad. |
